351 in a Mav?
Discussion in 'Technical' started by borculo, Aug 29, 2009.
  1. baddad457
    Except the Mustang II, which used a 147 tooth bell :biglaugh:
  2. madman21
    madman21 Beer is good
    Albuquerque, NM
    1976 2dr Mav 410ci
    I'm not sure I understand your motivation on this board... Are you here to help or spread your chaos?
    This detail is not important to what this guy is asking about. This is why most forums are trash.
  3. baddad457
    I'm here to straighten out the mess you started by telling someone that 351's needed a different bellhousing than a 302. And at this point in time, anything (157 or 164 tooth)can be found behind any 302 or 351. The Mustang II 147 tooth is yet another. It's not likely you'll see one, but the possibility is still there.
  4. madman21
    Albuquerque, NM
    1976 2dr Mav 410ci
    The majority of 351ws ae used in heavy applications with 164t flexplates. I'm not saying they can't be found with 157t, but odds are one from the junkyard will be 164.
    This argument is pointless....
  5. gulupo
    gulupo Member
    nuevo laredo,Monterrey mexico, Laredo Tx
    1970 ford maverick
    for once in your life do what your wife told you.:clap:
  6. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    Dang, this forum sure has changed. Sorry for any MIS-information I helped spread. I sure did not intend to do that.
    clint
  7. johnson
    johnson Member
    fargo, ok
    69.5 maverick
    hmmm. i have a 90 vic with the windsor. maybe i should get it ready to put in my polive clone mav
  8. baddad457
    If you do, don't throw out the oilpan & pickup tube. That's the one needed for a 351W in a Fox body Stang and also in a V8 Ranger swap using a 351W.
  9. baddad457
    No, it was only pointless to you. :naughty: You questioned cdeal28078 for making the statement that the 302 and 351's used the same bellhousings, your questioning this was a false statement that needed to be corrected.
  10. baddad457
    You never made any misleading statements that need appolgies for.:thumbs2:
  11. FishnRace
    FishnRace Jamie
    Solomon's Island, Maryland
    '72 2dr 351
    Alright folks, lets focus on the question that was asked :rolleyes:
    My 2 cents ... Cooling system upgrade is highly recommended.
  12. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Clint,
    You didn't mislead anyone.
    The finger pointer needs to point at himself.
    Any bellhousing flywheel/flexplate combo that will fit a pre-80s 302 will also fit a 351w or 351c. It's that simple.
    You were dead on.(y)
  13. madman21
    Albuquerque, NM
    1976 2dr Mav 410ci
    They will fit with the proper flexplate. (y) You were not wrong Clint.
  14. nickg
    nickg New Member
    Maine
    1976 comet 2dr 351w
    I need any help I can get at this point please I have a 1976 2dr comet and I have been trying to put in a 351w for about two years and im still stuck. I am about ready to give up I don't know what i am doing wrong. exhaust manifolds are hitting PLEASE ANY HElP
  15. rayzorsharp
    Welcome aboard! :Handshake
    I suggest doing a search on this board for "shock tower shave" and that will end your problems. It is possible to do it without shaving but very difficult to change plugs without jacking up the engine and you'll have to find the correct combo of manifolds or headers. It's much easier to put a 347 stroker in it for the horsepower unless you just insist on the 351. There are a few guys with the 351's but no way in heck I would do it. Best of luck to you whichever way you go. (y)
