351 in a Mav?
Discussion in 'Technical' started by borculo, Aug 29, 2009.
  1. gulupo
    gulupo Member
    nuevo laredo,Monterrey mexico, Laredo Tx
    1970 ford maverick
    you need to cut the shock towers. theres a mod you need to perform in order to install the 351. check out the forums.
  2. nickg
    nickg New Member
    Maine
    1976 comet 2dr 351w
    WOW! Thanks for the fast reply. I have had the towers shaved as far down as the control arms. I tried the maverick 302 engine mounts and the engine sits too low. I took the manifolds from a donor maverick and still no luck. I now have 1973 ltd mounts which are taller but now my drivers manifold hits my steering box. I must be doing something seriously wrong. My ears are open to any questions or ideas it will kill me to sell this car.
  3. nickg
    nickg New Member
    Maine
    1976 comet 2dr 351w
    ok I think I just figured out my problem. My towers are only shaved down to the control arm. The center bulge under that was left still and that is what I am hitting.
    Thanks.
  4. tim keck
    sharps chapel,Tn
    I think what they're trying to tell you is that the pre '80 302 is balanced the same as the 351, so if it IS the smaller bell (that takes a 157 flex) he can just use the 157 flex in place of the 164 and it'll work. Least that's what was done when I put a 351w in a '71 250 car & used it's existing tranny, just rounded up an old 157 flex & threw it in.
    But don't feel too angered/frustrated, most of the time Ford parts don't fit other Fords anyway.:biglaugh:
