351 swap
Discussion in 'Technical' started by warboy, Sep 13, 2016.
  1. warboy
    warboy Member
    pennsylvania
    1972 ford maverick grabber, 1977 ford maverick 4dr 351 v8
    so i decided since i already have a very clean 351w sitting in my 4-door maverick parts car, im just gonna drop it into my 72 grabber instead of a 302. i intend to keep my manual steering and im putting disk brakes (do i need the brake booster for front discs or can i just swap the proportioning valves??). i want headers in my car too with my exhaust exiting before the rear tires. i just have a few questions
    - do i need the brake booster for front disk brakes
    - can i just wire the 351 using the 250i6 wiring harness
    - can anyone recommend headers that dont need any mods to fit
    - should i install a floor shifter (maybe a quarter stick hurst shifter)
    any more info on this would be appreciated
  2. William623
    Orlando
    1973 ford maverick grabber
    You do not need a brake booster for front disks. Most people run manual.
  3. Mavman72
    Dont use the power brake master with manual brakes...No one makes a header that works on a 351 in a mav without mods.
    You can use the the 250 harness for your swap. gonna have to stretch a few wires...re-rout a few etc...
    Put a floor shifter in it...less problems when useing headers
    You really dont need to change the prop valve when going to frt disk brakes
  4. warboy
    warboy Member
    pennsylvania
    ive heard that a few places make headers for the swap, ill make some phone calls
  5. warboy
    warboy Member
    pennsylvania
    now with a healthy 351 in a light car such as a maverick with a fresh trans and a good shifter, am i looking at a good set up for a street/strip car
  6. warboy
    warboy Member
    pennsylvania
    now i see in your description that you have a 351 maverick, do you mind showing me a picture of your engine bay so i can see how its set up?
  7. Mavman72
    Shure!!! I did not do this install. If I had...I wouldnt have had to pull it twice to fix/correct issues the original installer didnt seem to care/know about.
    Last pic is how it looked when I got the car.
    2nd pic is the 3 row aluminum rad thats in it now.
  8. warboy
    warboy Member
    pennsylvania
    dang, that engine sure looks good in a maverick. i cant wait to start my swap. from what i read crites has some 351 mav headers that fit with very little modification
  9. warboy
    warboy Member
    pennsylvania
    just some questions about the 351, will it boil my back tires or not
  10. Mavman72
    They do make good torque...
  11. Hotrock
    Munroe Falls, Ohio
    You don't need a 351 for that! :yup:
  12. mojo
    What the neighbors say bout all the smoke? Looks like you've done a few burn-outs on that driveway B4?
  13. Mavman72
    Nope...Ya dont but, I use what I have...
    Hello Everett...Wasn't my driveway...LOL...
    The 1st pic actually ended up in the car craft magazine burnout section a few yrs back.
    mojo likes this.
