351 upgrade
Discussion in 'General Maverick/Comet' started by Phat mav, Mar 4, 2017.
  1. 71gold
    what are you going to use this car for and how much HP do you want?
  2. Lee Richart
    Lee Richart Member
    Redford, MI
    1973 Maverick LDO 421W
    If you are mechanically inclined, go with the 351. If not, stick with the 302 or a stroker version of that motor. I have a 351 stroked to a 421 and it is a blast. You can change the heads and the plugs without cutting the spring towers. It just takes careful planning. The plugs are easier if you remove the valve covers. I can do it in about an hour. By the way, my little sleeper has run a 12.34 @ 110mph.
    Lee "THE MAV" Richart
    Shorty likes this.
  3. Hotrock
    Munroe Falls, Ohio
    If I had it to do over again, I would probably keep the 351W and further modify it as I had already completed the task of installation. As others have stated, why go through all the work of installing a 351W when you can install a 302 based stroker motor up to 363ci. (I would purchase a stroker short block and build from that point.)
    https://www.summitracing.com/parts/mll-bp3472/overview/
    http://www.coasthigh.com/P3471F-GT-F347-SB-p/p3471f-gt-f347-sb.htm
    My thoughts on installing the 302 is there is just something satisfying about kicking some butt with a peanut motor.
  4. bartikus
    bartikus Member
    salt lake city, ut
    I installed a 351w in my comet back in 2006. To get the headers to fit i took a hammer to the shock towers. Now that i'm getting ready to do a full resto on the car I have to rebuild my towers. I wish I hadn't smashed the crap out of them. But at the time I was a stupid kid. We dropped a 351w in my brothers 75 grabber. We didn't notch the towers and ended up using a passenger side exhaust manifold from a 66 mustang with a 289 and I believe the drivers side came from a 66 fairlane with a 289. It is tight and we had to grind some of the bumps off the passenger side manifold. He would have stayed with the factory 302 but we picked up a rebuilt date coded 69 2 barrel 351w from pick and pull on half price day. It was in a 72 mustang. It would defiantly be easier to stay with the 302 but if you are really good at making things work I would say go for the 351w.
    Ronald Hopkins likes this.
  5. schroensr
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    All this talk makes me want to put in a 429 super cobra jet motor.
    Gene Fiore likes this.
