351W cam into a 302??
Discussion in 'Technical' started by Dave B, Aug 31, 2008.
  1. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    My 302 has a 351W/HO 302 cam:
    Holman Automotive
    Hydraulic flat tappet XX290
    .470/.474 lift
    290 degrees duration
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
  3. ratio411
    ratio411 Member
    Pensacola
    Voodoo split duration!
    Cool. That will shake the car a little.
    I can't use that due to stock heads and push in studs.
    That .488" on my cam makes me nervous about pulling studs.
    I have heard of lift as low as .474" pulling a stud on an SBF.
    That Voodoo would be an excellent nitrous cam...
    If you are not using nitrous, and using aftermarket heads, you may not really need all that extra duration on the exhaust. That is generally used to aid stock heads with restrictive exhaust, or with nitrous. Not that it would hurt anything. Just thinking aloud.
    http://store.summitracing.com/partdetail.asp?part=LUN%2D61002&autoview=sku
  4. maverick5.0
    maverick5.0 Member
    Caribbean/Puerto rico
    1976 maverick,347 stroker,c-4,sm bumpers,frt air dam/73 maverick,5.0 grabbber hood,four on the floor,v8,rear spoiler,...
    chebby got on the bandwagon with the 4/7 switch...on the new small blocks
