351w cam selection, need help
Discussion in 'Other Automotive Tech & Talk' started by MaverickDan, Nov 6, 2014.
  1. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Clean truck, love the 2 tone but I may be biased. I saved mine as well, bought mine from the wholesale lot at the dealer I used to work for. Mine also only had about 1 qrt of oil in it. The truck runs good but is weak and the timing cover leaks coolant.
  2. Krazy Comet
    Looks good to me, wanna trade??? ;)
    Actually a B&W or R&W are my favorite, but I done so much work to this one(ball joints, rear fuel pump, trans flush, recharge A/C, new radiator, headliner, plugs & wires, tail pipe etc, plus other stuff I'd already mentioned) guess I'll keep it, plus nothing leaks... Only problem is it could use radius arm bushings and gauge doesn't work on front tank(needs float, works for a while if I run it dry and let it set a few days) Has 182K mi...
