351w in my 74
Discussion in 'General Maverick/Comet' started by bigblockmav74, Apr 29, 2015.
  1. bigblockmav74
    bigblockmav74 Member
    1974 maverick
    My car came with a 250... will my c4 work with a 96 351 windsor and also I've heard so many opinions on weather or not I have to shave my shock towers ?
  2. don graham
    It'll fit, but if you don't shave the shock towers you'll never want to change plug
  3. Earplug
    Earplug Member
    Brighton, Colorado
    1974 Comet
  4. Mavman72
    Heres what you get without shaved towers...And headers...
    Gorilla who installed engine (Not me) beat towers mercilesly but didnt have to.:huh:
  5. Hotrock
    Munroe Falls, Ohio
    When I had a 351W in my Comet without shock tower modifications, changing plugs was about as difficult as with my current 302. What you cannot do with the 351W is remove the heads while the engine is still in the car. You have to pull the engine to remove the heads.
  6. Mavman72
    Did you have head studs??? If so then yeah, not pulling heads without pulling the studs... Other wise, they come out just fine.
    It takes me 20 minutes to change the plugs in my Sprint.
  7. Hotrock
    Munroe Falls, Ohio
    Mavman72
    I did not have head studs. I was running a set of headers made by J Bittle America that were manufactured about 25 years ago. I could not get to the lower head bolts because the headers were in the way and I could not remove the headers without pulling the engine. What headers are you running on your 351W? Can you get to your lower head bolts without removing the headers? Can you remove the headers without lifting or pulling the engine?
    I was of the opinion all the 351w headers blocked the lower head bolts.
  8. Mavman72
    They are sumitt headers, dont remember the PN# I can shove them out of the way enough to get to the bolts but it is a P.I.T.A.
    I do pop the engine off the mounts to get to the plugs, but thats easey to do on these cars. Two bolts and a jack and bobs your uncle...
  9. Hotrock
    Munroe Falls, Ohio
    "I do pop the engine off the mounts to get to the plugs, but thats easey to do on these cars."
    I never had to lift the engine to change plugs on my 351W with the JBA headers. Removing my tall valve covers did make access to the plugs easier however, their removal wasn't necessary. As I stated before, changing plugs on my 351W took about as long is it does with my 302.
    I've attached a couple of pictures of my 351w and the unmodified shock towers.
  10. bigblockmav74
    1974 maverick
    That's not shaving that's removing them lol.. And changing the suspension !! To upper and lower a arm ? I'm not going that far.. It can't be as bad as my dad's 69 mustang with a 428CJ to change the plugs ?
  11. bigblockmav74
    1974 maverick
    Which headers will I need ?
  12. Hotrock
    Munroe Falls, Ohio
    My headers that were designed and built by JBA 25 years ago were never put into production. I own the only set. There are now several sources that make headers for the 351W conversion. Tubular Automotive and Crites Restorations are a couple of suppliers.
    I'm not familiar with a Summit brand of header that fits a 351W conversion. It would be good to know the part number for your headers.
  13. bigblockmav74
    1974 maverick
    Thanks for the info.. I'm just starting this project so it will be a while before I need them :) im starting tear down today !
  14. bigblockmav74
    1974 maverick
    I have a complete a/c set up on my car that I won't be using if you know of anyone who would want it ?
  15. Rasit
    Rasit Member
    SE Pennsylvania
    List the a/c set up in the classified section, I'm sure somebody could use it.
