351w need another oil pan
Discussion in 'Technical' started by Bioinfomatic, Jul 3, 2008.
  1. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    So basically cut a hole in the oil pan, and bridge the gap.
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Why would you not use the dipstick in the timing cover???:huh:
  3. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    I didn't know you could check the oil levels from any other point on the motor, other than the dip stick tube that resides in the oil pan.
    So what you are saying is that if I buy a front sump oil pan, without a dip stick tube I can check the oil levels from the timing case cover, how so?
  4. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    Some older smallblock timing covers had a dipstick in them. Most of them have the boss there on the passenger side (left side if you're looking at the front of the engine). You can get an aftermarket dipstick and tube and drill your own hole in th cover.
  5. baddad457
    Ditto, Advance and Autozone both stock chromed small block dipstick tubes and sticks that are perfect. Got one on my 331. Drilled the hole thru the timing cover myself.
  6. ratio411
    ratio411 Member
    Pensacola
    The timing cover dipstick is why you find all sorts of front sump pans without provisions for a dipstick.:huh:
