351w swap with gt40p
Discussion in 'Technical' started by gasjunkie, Oct 5, 2010.
  1. gasjunkie
    gasjunkie Member
    uniontown, pa
    1972 maverick
    sorry bout the insult. you guys are right i could have listed the website. and i thought you were implying that i didn't search. my fault. im not up on my forum ettiquette. anyway i agree it would be nice if they refunded you when they tell you something will fit and it doesn't and i know about the firewall issues. they have another set for early falcons which i thought might be better the ff6 but not made for gt40p. ill check out the crites site thanks.
  2. Scrapper
    Scrapper Member
    headers
    ok im a new guy and dont know too much of anything. i have been doing a lot of checking around and wanted to know the for sure fits of headers on a 351 w in the mav if there are any that dont need mods
  3. maverick75
    Crites are the only ones, unless you want to do something custom....
  4. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    Jesse (a mav owner on forums), in spokane said he flipped his headers upside down and had them coming up then down & back to side rear wheels.
  5. Bryant
    need to see pics of that.
  6. maverick75
    X2. Fenderwell headers! :D
  7. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Personally, I would have taken his posts (actually I did) the same way you did. They came across to me as a bit snotty, could have been worded differently. Things can be taken way wrong when you aren't face to face.
  8. scooper77515
    I would like to see pics of those upside down headers. Of course, if I had mine mounted upside down, I would also mount them backwards and put a hairdryer or two on them.
    Or straight up out the top of the hood, with a glasspack on them??? That would be pretty cool. Anybody ever see anything like that?
  9. scooper77515
    kinda like this, but dualled out!!!
    [nomedia="http://www.youtube.com/watch?v=3DtcsIR-efQ"]YouTube - Mercedes Diesel Hood Stack[/nomedia]
    By the way, how do we embed youtube vids into our forum?
  10. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
  11. bmcdaniel
    Saw a car at a cruise-in last summer (think it was a SBC) with two carbs, a carb supplying each head through the head's exhaust ports and headers sticking straight up from the head's intake ports. Required a special grind cam and obviously it's now breathing through small exhaust valves, but it was different looking.
  12. scooper77515
    Sounds like an awful lot of work, to be different. :90:
  13. Clintd
    Clintd Member
    Parlin NJ
    75 maverick, 89 Cougar (sleeper), 04 Superduty and a 87 Cougar
    A header trick that works on everything but I never tested on a Maverick was to take the stock Explorer steel manifolds and cut all of the tubes off leaving only the side that goes to the block. then grind them smooth and use them as spacers to move out the headers about a 1/2" which is just enough the keep the plug wires from burning off. Order 2 sets of exhaust gaskets for a 91 T-bird with a 5.0 and you will never get a blow out and buy allen head screws from Home-Depot that are about 1 1/2" long to install them to the block.
    I'm thinking of taking a set and having them angle milled to see what happens as far as clearance.
  14. scooper77515
    I did that, put a multi-layer gasket between all surfaces for another 1/8" clearance, used $16 EACH shortie Accel spark plugs, and took a plug socket and cut 1/3 of the wall away so I could slide it on at an angle. I also had to drill the socket out so the plug tip would fit through it, and shortenend it just enough to reach the threads, then used an open ended wrench to remove the plugs.
    Still was just easier to pull the header all the way off, or at least jack up the engine, drop the exhaust on that side, and drop all header bolts but the front one so I could swing it out of the way.
    After 2 years of that, I went back to GT40 non-P heads.
    I would never want to do that again.
    Before and after images of the plug socket...
    [​IMG] [​IMG]
  15. maverick75
    Isnt that how Indy engines are? Ive seen Ford ones that way..... It was on some falcon i think. It has the header coming out from the top of the engine going to a turbo :) I gotta find the link to that car....
