3G alternator upgrade wiring
Discussion in 'Technical' started by lowriderick, Aug 26, 2007.
  1. scooper77515
    I would highly recommend the inline fuse.
    Kinda fuzzy picture, but you can see the $35 Autozone inline fuze on the shock tower. If it trips, you just lift the hood and reset it, and back on the road.
    Keeps the 130A alternator from melting everything else i the car in case of a malfunction.
  2. 70 maverick
    70 maverick Member
    Ajo, AZ
    1970 Ford Maverick, 76 Mav for parts
    does anyone know if the alternator off a 2000 ford explorer would work for this swap
  3. scooper77515
    Do you have the alternator in hand? If so, put the model number on google and see what it is rated at.
    If I recall correctly, I asked for one for a 93 mustang, v8.
  4. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    1974 grabber, 1995 mustang GT, 1967 mustang coupe, 1956 Caddilac sedan Deville
    This info from a foxbody site on the conversion but should be relivent in this thread as well, esp if you have a serpentine setup.
    These cars have 3G 130A clocked at 12:00 and will require fox bracket notched:
    94-95 GT Mustang
    94-06 V6 Mustang
    94-97 3.8L Thunderbird **NON-S/C**
    94-97 V6 t-bird
    These cars have 3G 130A or 110A in a larger case clocked where connector will be jammed under the bracket. You can make these work, but they're not the ideal 3G for fox app upgrades:
    93/94-99 3.0L Taurus (not 3.8L, check the 93, this may or may not have 3G)
    95-98 3.0L Windstar
    Small case 3G 95A with correct clocking and correct regulator. Some have incorrect 2 groove pulley, some have correct 6 groove:
    92-94 3.0L Aerostar (early 92s were 2G not 3G, so check before you buy)
    96-97 F series pickup with a 7.5L
    Some of these use larger cased alternator, but can work, not all 3G's were 130a, see info here
    Other, not sure of their clocking or output:
    94-04 3.8 (-98? small case, 95a?)
    3.8L 94-97 T-bird/cougar
    94-96 F-150 5.0L and 5.8L came with both 130A and 95A
  5. ptpdub
    ptpdub Member
    canada Sk.
    pulled mine off a 95 escort. had to enlarge a hole for a mounting bolt and it bolted right up
  6. maverick75
    Also 4.6L pieces WONT work. Theyre 3g but the rear case is different. I used one off a 93 taurus. Then i sold it, its living now in a ten second fox body :D
