4 link rear suspension
Discussion in 'Technical' started by Fred McCutcheon, Apr 6, 2010.
  1. tmcbride415
    tmcbride415 Member
    1972 Ford Maverick 200 Strait 6
    I definitely second this, I would be so happy if somebody figured out how to make rear coilovers on a maverick work
  2. mojo
    Think I saw rear coil overs one of the FB forums! Requires someone w/ talented fab skills.
  3. 2MCgts
    2MCgts Member
    Loganville, GA
    75 Comet
    I used a 67/68 mustang 4 link on my Comet , cutting it down to 3 link. It did cut the use of backseat but I didn’t care cause I also did a tub job. Had this talk with several companies of doing a link set up for Comet/Maverick but the back seat always came up .
    Jaybee, CaptainComet and Hotrock like this.
  4. CaptainComet
    I have driven a couple cars with three links and really liked them. They track well, even on rougher surfaces.
  5. 2MCgts
    2MCgts Member
    Loganville, GA
    75 Comet
    I myself had never driven a older vehicle with a link set till my own was done. A world of difference plus add in the adjustability with coil overs. Makes for much much better ride and Zero body roll with the added frame work
  6. mavstang 71
    mavstang 71 Member
    placerville ca
    71 maverick
    We’re you able to use the front leaf mount for the lower bars? Do you have any pictures of your upper link from under the car and inside the car?
  7. 2MCgts
    2MCgts Member
    Loganville, GA
    75 Comet
    I was able to use front leaf spring mount . And a very good thing I went to take a pic of it cause the bolt was backing out. I’ll put a pic of arm on chunk but you can’t really see it mounted on inside of car cause I have it enclosed in metal with a small opening for adjustments. 6E87BA0C-D9A5-4A10-848A-F56D5EDB2D12.jpeg 8723B843-353C-4C32-9785-FAD08713CDEE.jpeg
    CaptainComet and Jaybee like this.
  8. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Your 3 link looks like it would work with a seat on each side and an armrest in the middle.
    CaptainComet likes this.
  9. CaptainComet
    Going by the rust on that bolt, it has been backing off a while. Yikes! Lucky catch there.
    The crossmember between frame rails in front of the former leaf spring mount ... is that for the upper arm?
    Thanks for posting the pictures. Giving me ideas here. Now if I just win the lottery ... :happy:
  10. 2MCgts
    2MCgts Member
    Loganville, GA
    75 Comet
    Yeah you’re probably right about the bolt ! Over the last couple of years my lack of mobility has taken a hit due to my Ataxia which is similar to MS so my wrenching abilities are all but gone. The Comet is mostly used for Autocross but now is actually “technically “ street legal but it does sit for periods of time. It went to shop this week to get a couple of things done so I had him go over bottom side to tighten check everything! Getting ready to hit some weekends of Autocross starting in September with a partner so I can go and have help at track . Getting a young neighbor started in Autocross . I’ll post pics when she goes tracking in September ! A car girl !! Her husband isn’t into cars but she’s very excited learning the Comet and to autox.. It’s a win win for her n me .
    That was the arm you made reference to ...
  11. 2MCgts
    2MCgts Member
    Loganville, GA
    75 Comet
    Now I get what you were asking.... the crossbar to the right is some of the metal work for frame connector. I added that front n the back on each floor for strength . The round bar to left is driveshaft loop 7FF27BC9-5899-4DFF-BE1F-DB72AD9EEF14.jpeg 4E9033BB-B593-49D4-946F-02481E3729EC.jpeg 1B87B18D-CCDC-4F71-955C-14720BD4EA42.jpeg 37047454-C6D8-422E-B225-0E0C2BF5BBE9.jpeg
  12. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Ah, well...looking at it from the inside that would be a TALL armrest!
  13. 2MCgts
    2MCgts Member
    Loganville, GA
    75 Comet
    Yes it would be !! If I had wanted backseats I’d have probably had it done differently. Don’t have a backseat in either of my Comets
  14. Steven7777
    Steven7777 Member
    Verona, Kentucky
    71 Ford Maverick
  15. 71gold
