4 lug disc brake conversion kit
Discussion in 'Parts Interchange' started by ComMavDean, Nov 11, 2021.
  1. ComMavDean
    ComMavDean Member
    New York
    72 Comet GT
    Does anyone know if a disc brake conversion kit is made for a 4 lug? I’m thinking not as all I find is 5 lug. Bad enough going 5 lug I’ll have to change both front and back I don’t want to have to change wheels too. Thx!
  2. Krazy Comet
    Dismal Swamp
    I've seen this kit but I have no idea if it'd work on Maverick.
    If it also fits '67-'70 Stang would fit Mav/Comet.
    As far as a specific kit for our cars, better chance winning the Powerball.
    ComMavDean likes this.
  3. ComMavDean
    ComMavDean Member
    New York
    72 Comet GT
    Ok thx for your input I’ll check it out. I’ve seen Maverick 5 lug conversion kits but not 4 yet.
  4. 71gold
  5. Powerband
    Powerband Member
    NY's \H/
    I used 71 Maverick 4 lug spindles on my '61 Comet. The 4 Lug Disc Brake conversion is from 'SCAREBIRD CLASSIC BRAKES'
    https://scarebird.com/index.php?route=product/category&path=65
    Simple 4 Lug Disc front brake conversion uses Scarebird backing plate with GM Calipers and Nissan Rotors. You can use all their parts or assemble your own ...
    Disc conversion will also need Frt/Rr proportioning valve added to rear brake line for any front disc upgrade.
    Hav E fun
    Maverick 4 Lug Spindles - Disc swap
    [​IMG]. [​IMG] ., [​IMG] .
    [​IMG] . . [​IMG] . [​IMG]
    ... [​IMG]
  6. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
  7. Acornridgeman
    Wisconsin
    Older thread but I wanted to add some info - Scarebird has gone out of business :(
  8. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Oh, I'm very sorry to hear that about Scarebird. They were a great option for affordable disk brakes.
  9. TeeEl
    TeeEl Senior Member
    Colorado
    5-Lug is better...
  10. old55guy
    old55guy Member
    Flat sac , Ca.
    Scarebird web site back in buisness in August this year , I may be the first customer ?????
    TeeEl likes this.
  11. old55guy
    old55guy Member
    Flat sac , Ca.
    Hello guys ,Maybe you guys might have more info on this kit for me ? https://www.ebay.com/itm/205705535782
    Seller answered this ??
    I'll give you the history of Ford spindles. Only 1960-1966 had different spindles for 6 and V8. Starting 1967 all spindles, 6 and V8 were the same. Same for 1970-75 except they increased the bearing size for 1970-75 ( Quote )
    I really want a bolt on kit for my 1970 four lug spindle , Anybody have in info if this will work ??
  12. Craig Selvey
    As far as I have ever seen on a Maverick, the 4-lug spindles are different than the 5-lug spindles. The 4-lug spindle is smaller/not as thick.
  13. Krazy Comet
    Dismal Swamp
    Ford Master Parts says only spindles before 8-25-69 are smaller. ('69½ same size as other '69 models) For '71, no differential in spindles between 4 & 5 lug. Spindle size increased for all '70 models.
    Powerband likes this.
  14. old55guy
    old55guy Member
    Flat sac , Ca.
    I guess the big ????? Is will that brake mount bolt up to the 4 lug spindle ? Up until now i searched for years to find a bolt on brake kit , This must be a new item ???? I will let you guys know if it fits ,,,, I know it 5 lug but that a easy fix ,
  15. TeeEl
    TeeEl Senior Member
    Colorado
    If you had gotten some Maverick/Granada disc brake spindles, you'd already be done...
