4 lug disc brake conversion kit
Discussion in 'Parts Interchange' started by ComMavDean, Nov 11, 2021.
  1. old55guy
    old55guy Member
    Flat sac , Ca.
    FUNNY GUY YOU GOT ANY TO SELL
  2. Powerband
    Powerband Member
    NY's \H/
    not certain , only seen what i've seen - i'd like to confirm if possible with "factual" info
    the three vs four brake plate bolts for 6 or 8 and Disc or Drum and changes in mid '74 is whats confusing...
    Maverick pre mid '74 6/8 Drum Spindles are the same (?) and spindles all have four retaining bolts ?
    Maverick pre mid '74 (V8) Disc spindles all have three brake plate bolts?
    Mid 74 and later 6/8 cars all have the "Granada" 5 lug DISC spindles and all have THREE bolt plate AND the hub/bearing size enlarges ?.
    Early (pre- mid 74) Ford 5 lug wheels all (?) have the smaller center hole for smaller pre '74 hub/bearing size (?) ( and less offset wheels for drum brakes )
    '71 Maverick 4 lug spindles
    76 Disc spindles
    have fun
  3. TeeEl
    TeeEl Senior Member
    Colorado
    They're available new...
  4. Powerband
    Powerband Member
    NY's \H/
  5. Krazy Comet
    I suspect all drum spindles used for Fairlane, Torino, Falcon, Mustang (thru '73) and Maverick are same. Four bolts are required as the backing plate secures brake shoes. On disc brakes caliper is bolted directly to spindle, backing plate is nothing more than splash/dust shield, three bolts are plenty, I used '69 Torino discs on my Comet (pictured). Found one was small bearing and other was large. Only difference is bearings, rotors are same for either.
    There's note in Master Parts to beware of bearing size as Ford was suppling the large bearing spindle for replacement.
    Powerband likes this.
  6. TeeEl
    TeeEl Senior Member
    Colorado
  7. old55guy
    old55guy Member
    Flat sac , Ca.
    Thank you guys !!! I am going to buy this 4 to 5 lug kit , I appreciate all the Help ,I do not have a HOT ROD ,just a 250 ci. driver
    Krazy Comet likes this.
  8. Krazy Comet
    I forgot to mention, when I installed the Torino brakes on mine, I'd checked drum part numbers for '71 Torino & '71 Maverick. They are same, I figured since drum could swap, was no reason I could not use the Torino disc. I now know of a '69 Mustang that has Granada brakes.
    The '67, four piston disc brakes will bolt to later drum spindles, have a set on my '69 Fairlane.
    old55guy and Powerband like this.
