4 Lug Question, rear end......
Discussion in 'Technical' started by captainmack, Mar 28, 2006.
  1. captainmack
    captainmack Quad Door
    Ok.....so what is wrong with the 4 lug? Why is everybody switching to the 5 lug?
    I am still figuring all the stuff I'll need for my 302 into my 200-6 swap, and this is one of the last things....I have already considered rear ratios... is it just about bigger tires and brakes....disc, that is? My rear end is 8" if I'm correct and am going to build a highway cruiser, not a dragster.( I might get a little of both if I stick that AOD in, though...) I don't see any reason for the 9", (so far). A limited slip would seem like a nice thing to have.....any thoughts, ?
    Thanks:rolleyes:
  2. Jamie Miles
    Alto, GA
    I've had a few
    Mainly for the fact that it is 5 lug. Alot more wheels available for 5 lug.
  3. Mavaholic
    Also the brakes are bigger on the 5 lug and disc are only available in 5 lug. A 9" is not needed in most cases.
  4. don graham
    disc brakes are a safety factor. no need for a 9". the 8" is good for about 350hp. that's subject to opinions. definitely a lot of wheel options on the 5 lug. if you change to the 5 lug rear end. you need to change the front so you can get the same wheel pattern. unless you like to carry 2 spares.:)
  5. sierra grabber
    sierra grabber Certifiable
    northern nevada
    call the yards in hayward and fremont/newark.there are a lot of mav parts. found my front discs there and my uncle pulled a center for his mustang from a four door there. got them on half off days too. if i still lived in that area id have new boomerangs already. dont forget you can use the front spindle off of other cars as well so search the board for as much info as you can before you go.(y)
  6. stmanser
    Davenport, Iowa
    if anyone can find 4 4lug rims for me in the 15x7 size i will be very happy...
    that is why... no rims.. and i have looked everywhere.... well almost everywhere
    you can get them made... for 150 a piece... or more
  7. captainmack
    I just found a '76 Mercury Monarch for 300 dollars...... my research says this car will have lots of parts.....brakes... I hope the guy calls me back :)
