4 Lug vs 5 Lug Axle Bearings
Discussion in 'Technical' started by Acornridgeman, Jan 6, 2006.
  1. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I know you have established the OD of the bearings, but what about the ID? Are the axles the same OD? If so, why couldn't you put the 4 lug bearing on the 5 lug axle, then redrill the 5 lug backing plate to the 4 lug end pattern? Just thinking outloud.........
  2. Acornridgeman
    Wisconsin
    Good thought, but according to the smaller 4 lugs bearing number Jamie provided, it is a slightly smaller ID too. I do remember reading posts about the brake backing plates being drilled out for some applications.
    Good input! :tiphat:
    Update: I just posted the bearings specs below - you can see the shaft size is smaller!
  3. Acornridgeman
    Wisconsin
    Just tried to link the Timkin catalog but it failed to link. You can go to Timkins online catalog and look them up for yourselves.
    Oh well, Timkin has a definate listing for the 4 lug bearing for a 70 to 72 Maverick. they also list the 5 lug bearing. Here are the numbers.
    All 5 lug 8" ring gear axles =RW207CCRA
    Bearing Bore 1.3780
    Bearing O.D. 2.8246
    Bearing Width .8449
    Bore (B) Inches 1.378
    Bore (B) MM35
    Collar I.D.1.3752
    Collar Number R-88107-A
    Collar O.D.2.095
    Collar Width.3980
    Inner Ring - W2 Inches 0.8449
    Inner Ring - W2 Metric 21.46
    OD (D) Inches 2.8346
    OD (D) MM72
    Outer Ring - W1 Inches 0.8449
    Outer Ring - W1 Metric 21.46
    Type4Width (W) Inches 0.8449
    Width (W) MM21.46
    All 70-72 Maverick 4 lug axles =RWF34R
    Bore (B) Inches 1.3386
    Bore (B) MM34
    Inner Ring - W2 Inches 0.9449
    Inner Ring - W2 Metric 24
    OD (D) Inches 2.6772
    OD (D) MM 68
    Outer Ring - W1 Inches 0.8268
    Type5Width (W) Inches 0.9449
    Width (W) MM 24
    Hope this prints out OK this time.
    Eric J :drink:
  4. Just Jim
    Just Jim Member
    So Cal
    '72 Comet '62 Falcon '58 Morris Minor
    I don't have any specfic bearing sizes to list but do know that 5 lug axles wouldn't fit in my 4 lug 8 inch '72 Comet. The 4 lug bearing O.D is smaller than the 5 lug and the 4 lug axle itself is also smaller so the 5 lug bearings won't fit. I ended up getting a complete 8 inch rear from Pic A Part for $75 drum to drum.The u bolts and u bolt mount plates for the 4 lug 8 inch are also smaller than the 5 lug.
  5. tim keck
    sharps chapel,Tn
    Sorry to just get back,the 4-lugger was a '70 w/250 & c4.
  6. fredee
    fredee Member
    South MS.
    1971 comet
    I have a 71 4 lug 8 inch. So the center section will work in either, correct (4 or 5 lug). In other words can I use my center section assembly out of my 71 in a maverick or granada 8 inch with their 5 lug axles and larger brakes? If I use a granada rear end is their anything different other than it being 3/4" wider. Also is the 3/4" total or both sides 3/4" wider?
  7. Acornridgeman
    Wisconsin
    All 8" rears are 28 spline and will swap with each other. Ford did make a 2 pinion and a 4 pinion version (spider gears) but I have never personally seen a 4 pinion in an 8". But they all swap just fine.
    Maverick flange to flange is 56.50" and the Granada is 58.00" = so it would be .75" (3/4") on each side.
  8. fredee
    fredee Member
    South MS.
    1971 comet
    Thanks alot!!
  9. Speedy
    Speedy Member
    Dallas, TX
    '71 Comet GT
    Re: More ?'s
    This was a great thread as I read through it. It left me with a couple more questions though. I'm sure now that ya'll are "Rear-End" experts ya'll can answer my questions...
    1st. Can you buy a bearing that allows the use of the 5 lug axles in the 4 lug housing, or does the extra legnth of the axle prevent this?
    2nd. What does this do for the ranger rear axle swap? I thought I read that you can use the axles out of a Ranger to convert your 4 lugger to a 5 lugger.
    It seems the consensis is just swap out the whole axle. What are my options?
    Thanks,
    Dave
  10. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    No you need to get bearings for 5 lug only. Its the inside diameter that counts.
    The maverick rear ends are not interchangeable with other models. If you have a mustang II rear end you can put a 5 lug axle from a ranger.
    The bottom line is if you have a 4 lug and want to change it to a 5 lug. Than you need to swap the whole rear end.
  11. just1993
    just1993 Mike
    Zionsville, PA
    70' & 71' 2 Door and 76 4 Door
    How about having the 4 lug axles redrilled to 5 lug? Or buying axles from say Currie in Cali with the correct axle size and lug pattern?
  12. mike75mav
    mike75mav Member
    Bremerton, WA
    I would not want to redriffed to make it 5 lug. If Currie can totally machine a custom made axle to fit go for it. You are better off on finding a 5 lug rear end.
  13. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Why go through all that trouble and expense to keep a 'tiny tube' 8" rear???
    You could just get big 8" axle tubes welded on for less dough and use stock 5 lug axles.
    However, you could also get 8" tubes and stock 5 lug axles welded to a 9" housing center for the same moeny too. Then have a 9" rear.
    A turd with a bunch of money thrown at it is just an expensive turd.
  14. ratio411
    ratio411 Member
    Pensacola
    I just thought about that statement and realized that, though true, is still a silly way to go.
    A junkyard 5 lug 8" rear is dirt cheap.
    Much less than any of the modding we have discussed...
  15. Speedy
    Speedy Member
    Dallas, TX
    '71 Comet GT
    Re:
    True enough. I am thinking of buying another 4 door doner. I found one with a rebuilt 302 in it and thinking about the rear-end, the front disks and the engine/trans. I can get the car for $700-$800. I just have to make a 300 mile trip to get it. 600 round trip. My problem is with two younger drivers in the fam, and trying to keep them in a car, I already have one extra car that's not being used. An Escort. Plus the Comet. Momma has been very patient with me. If I bring home another car, she's liable to...I'm afraid to think about it. I live in a small suburb which really frowns on "spare cars" sitting around. Especially if it's sittin there w/ no wheels and tires. I really need to find another car hauler so I can dismantle the car while it sits on the trailer. Then, when I get done, I can just scrape it off at the local junk yard.
