4 speed automatic
Discussion in 'Technical' started by OLD GOOSE, Oct 5, 2011.
  1. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    I'm starting to think about the AOD swap. Does the C4 speedometer cable and gear fit in the AOD? I know the gear wouldn't have the right number of teeth.
  2. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    yes it will:dancing:
  3. Jsarnold
    '72 Sprint
    Great. Thanks.
  4. silver70
    silver70 Eric
    Phoenix, AZ
    '70 Maverick
    I had to shave my upper tranny tunnel support on my '70 to accomodate the AOD. The rib that the crossmember bolts to. The upper tailshaft housing flange bolts were hitting it and preventing the bellhousing from mating with the rear of the motor. I dunno, maybe that's just unique to the 1970's smaller trans tunnel.
  5. markso125
    markso125 Member
    Lewiston Ut
    The AOD fit just fine in my 72, i used franks crossmember and everything lined up perfectly...Now on the other hand I did have to cut it for my tremec TKO...but it was worth it:thumbs2:
  6. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    im installing a 4r70w into my comet.
  7. PaulS
    Are you installing an ECM and EFI?
  8. bomrat
    bomrat Member
    im installing efi and he ecu
