4 Wheel Disc Conversion
Discussion in 'Technical' started by Eddie Maverick, Feb 8, 2008.
  1. Mavaholic
    Frank, I would think you could buy just the master cylinder. But with very little effort, why not add power assist? I got it from ABS Power Brake in CA. THe number is 714-771-6549.
    A Granada unit will not work. It is too long so it won't fit behind the shock tower.
  2. 71gold
    thanks...:Handshake
  3. FoMoDave
    FoMoDave Maverick Owner
    Cumming Ga.
    1973 Maverick 302 c-4,1971 Maverick 6cyl
    Then there is always the Hydro-vac system route.......
  4. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Here's the wilwood one thats the same as the Chrysler unit
  5. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    Oh thats the one, thanks Derek. I wondered what it looked like. I paid 30.00 for mine, I'm willing to bet they'd ask a lot more.
  6. 73mike
    73mike New Member
    oxnard
    1973 maverick
    brakes
    where can I get one and from who? what car is this from? Thanks
  7. 73mike
    73mike New Member
    oxnard
    1973 maverick
    I'm going to be doing a conversion to disk in front. what is a bolt on kit and from what year of car?
  8. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    I dont think thats from a car directly. I'm sure he ordered it from a parts supplier.
    ABS Power Brake, look a few pages back for the number
  9. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Eddie,
    What is that M/C from? Is it disc/disc or disc/drum?
    Thanks!
    Russ
  10. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    Mavaholic, what car is that master cylinder from? also I assume it's from a disk/disk car correct? I wander if there is one that is for manual brakes... I have disk in front and drums in the back with a manual mc which feels fine to me.
    Here's a more general question... if you don't get the proper mc how bad would the disk brakes drag because of the residual pressure? I had to replace my mc afew years ago but I don't remember if I replaced it before or after I did the conversion and I don't remember which one I got.... thanks.
  11. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    I got it from a 1985-1993 Dodge D100/D150 1/2 ton truck.
    It's Disc/Drum, large bore. Mine is all done and the brakes feel real strong. I will have to adjust the prop valve when I get the car running, hopefully thats by next weekend. (Hopefully)(y)
  12. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Thanks! Mine is also disc/drum, looks great!
    Russ
