460 1972 Comet GT
Discussion in 'Maverick/Comet Projects' started by Trojan, Mar 13, 2019.
  1. Trojan
    Trojan Member
    Bakersfield California
    1972 Mercury Comet
    20191109_164729.jpg 20191109_164758.jpg cleaned up and painted, 3.50 geared
  2. Krazy Comet
    Dismal Swamp
    That's a light duty, single vertical rib case, better versions have two vert ribs. Does it use 31 spline axles?
    You mentioned '57 rear end but that D2SW-C carrier support is 1972 at earliest.
    Trojan likes this.
  3. Trojan
    Trojan Member
    1972 Mercury Comet
    The center was out of an 83 van, 31 spline. The rear axle housing is from a 57ish Ford, 28 spline axles. Gonna trade the 31 spline center for a 28 spline. Was the only one I was able to find after looking in 2 different pull yards.
  4. Krazy Comet
    Dismal Swamp
    While 28 spline axles are fine for small block and even mild 390, for a 460 I'd stick with 31.
    BBMS18 likes this.
  5. Trojan
    Trojan Member
    1972 Mercury Comet
    Know of any cars with 31 spline axles same length as ours? I'd like to avoid having to buy Currie cut-to-fit axles, to save some bucks, if possible.
  6. Trojan
    Trojan Member
    1972 Mercury Comet
    Finally picked up the housing, started removing rust with a gel. It's late, gonna prime,paint, clear tomorrow afternoon
    \m/ 20191116_223203.jpg
  7. Trojan
    Trojan Member
    1972 Mercury Comet
    Not the best picture, only one I took time to take though, more later.
    Gonna grab a disk brake set up outta some crown vics in about a week or so, will update once done. USER_SCOPED_TEMP_DATA_MSGR_PHOTO_FOR_UPLOAD_1574026982871.jpeg
