460 install first try
Discussion in 'General Maverick/Comet' started by JHodges, Sep 18, 2011.
  1. mav1970
    I would assume that this beast has a C6 behind it?
    I transplanted the front section of a larger 72 tunnel into my 70 for more room. Maybe you could do the same thing with a front of a Torino, Montego, LTD etc tunnel - something that was designed to clear a C6. Then blend it back into the driveshaft area of the tunnel :hmmm:
  2. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    You need to find a C4 from a early 400 powered Cougar/Elite/T-bird.
  3. JHodges
    JHodges thumper
    Dora Alabama
    I thought about it. You can get the bellhousing now with no trouble. I think when I put the clip in I put it in about an inch higher than usual since a couple guys have fit in a c6 with a stock tunnel
  4. JHodges
    JHodges thumper
    Dora Alabama
    there is a big hole in my floorboard
  5. JHodges
    JHodges thumper
    Dora Alabama
    the grinder and sawzall were useful yet again. I about have everything to clear, pics will be up tomorrow
  6. JHodges
    JHodges thumper
    Dora Alabama
  7. cobracleveland
    cobracleveland Member
    Altoona Pa
    70 torino hardtop,79 f150
    any updates? Im thinking about this swap ford a prostreet car.
  8. JHodges
    JHodges thumper
    Dora Alabama
    not really. when I pit the clip in, I put it about 2 inches to deep into the framerails and it threw the driveline and transmission angle off bad. I wanted it to have full travel on the uca and didn;t take into consideration that it woud squat and didn't need the downward travel. I may cut the clip out and redo it later but I don't have a lot of time now and I would rather fool with the 65 mustang or my ls1 camaro. The only advice I can give is to buy an aftermarket crossmember that will fit the car because there is a ton of cutting to get a factory one to fit
  9. igoback70
    igoback70 Member
    IN
    70 Maverick
    MY GAWD BUBBLES, WHAT HAVE STARTED TO FRIGGIN CREATE ! ( lol ) Should be really cool when you get it done.
  10. 71gold
    done yet...:bouncy:
