460 into mav
Discussion in 'Technical' started by AUSSIEBJ, Feb 22, 2006.
  1. RabidCustoms
    looks great!
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I give you some more perspective on top of that...
    The late 460s are dogs!
    Imagine that 460 in a Mav, then give it a whole lot more power!
  3. AUSSIEBJ
    AUSSIEBJ http://mmb.maverick.to/at
    NEW YORK
    70 Mav old race car project,70 mav 460 ,C6 9" posi 4.11rear SOLD
    Finally finished the right hand pass header now for the hard side all up 4 days into pass side ..here are some pics
  4. don graham
    that's one awesome set of headers. looking good.:)
  5. ratio411
    ratio411 Member
    Pensacola
    I knew the big ugly shock tower holes would be good for something! ;)
  6. Maverick Man
    California
    wow looking good! what clearance on the header to tire when turning?
  7. okibono
    okibono Member
    cali
    wow! I love cubic inches...
  8. Mavaholic
    Amazing!!!!!
  9. AUSSIEBJ
    NEW YORK
    :drive: When the tyre is on full lock to the right i have 1/4 of an inch between the header and tyre i think that should be fine..I hope .
  10. mercgt73
    mercgt73 Member
    If its not, you'll know when to stop turning. My Mustang rubs on hard left turns, and after a few rubs I kinda learned not to turn so sharp. I was thinking of welding a stop on the spindles... and since its a drag car and not a driver, wasnt to worried about it.
    Looks great though! Awesome!
  11. jayman
    jayman Member
    San Diego, Ca
    69.5 Maverick/72 Grabber
    I love the idea of a BIG engine in a small car. What are you doing for unibody strengthening? Big torque will twist the unibody pretty fast unless you at least put in subframe connectors.
    I wish I had pictures of the twisted remains of the Maverick that we stuffed a 390/4-speed into during the late 70's. Ran great until I dumped the clutch at about 4000 and popped the windshield out of the car. :yikes:
    BTW, I have seen quite a few MII conversions done. The Rod and Custom kit is one of the best designed kits available. All of the MII kits loose some turning radius compared to stock, but they really help to tighten up the steering and improve the ride.
    How is the ride height looking with the 460 in the car? Mine still sat pretty high.
  12. AUSSIEBJ
    NEW YORK
    with the stock spindles and bb springs from rod and customs the front was to high, i was surprised with the weight of the bb, so i now have a set of 2" lowered spindled and i cut a coil off the spring i will post a pic when it is back on the ground ..as long as the lower control arm is parrallel to the ground i will be all right....as for strenghtening up the chassis i will be adding to the cage and will make custom sub frame connectors to tie the car together i will post pics of that as well ....i am shooting to drive the car buy the end of august..i hope.....
  13. AUSSIEBJ
    NEW YORK
    Project has been on hold while i finish some other cars but i do have a question ..should i go with a power booster for the brakes or stay with a manual set up once i decide this i will build the drivers headers ..any feedback would be great.....Barry............................:huh:
  14. RabidCustoms
    the booster will eat up a little more room......that could be a deciding factor with header clearance?.....your call in the end though either way.;)
  15. Mavaholic
    I'd go with a booster if possible.
