"460ci" in mav WITH shock towers???
Discussion in 'Technical' started by scooper77515, Mar 18, 2006.
  1. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    No replacement for displacement. No susbistitute for cubic engines. Can't have too much power. Sheer brute torque. And anything you've heard Tim "The Toolman" Taylor say about mo' power.:yup:
  2. AUSSIEBJ
    AUSSIEBJ http://mmb.maverick.to/at
    NEW YORK
    70 Mav old race car project,70 mav 460 ,C6 9" posi 4.11rear SOLD
    scooper i just paid for my mustang II from Dan he was selling it on this forum its on the way my 460 will be in in no time i cant wait
  3. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    Hhhhmmmm.....now I know I suggested the big inch windsor but I will have to add something in response to this "pearl of wisdom". :coco:
    Try this one on for size 302-Boy:
    +.030" 460 = 466
    Keith Black hypereutectic flat tops
    Standard Sealed Power ring set
    Stock rods with ARP bolts
    Stock crank
    FRPP swap oil pan
    FRPP hydraulic camshaft/lifters/timing chain & gears
    Stock 1970 D0VE heads with 2.19/1.75 valves
    Used Crane 1.7 rockers
    Offy Port-O-Sonic single plane intake
    Holley 850 dp (out of the box)
    MSD distributor
    Hooker 2" swap headers
    C4 w/3500 stall converter
    4.11 gear
    28.5x10.5 slicks
    stock suspension fox body (1984 Thunderbird)
    weight: 3345 w/driver
    10.35 @ 136 mph.....all damn day long.
    Total investment: $6500 (and that includes car, engine, tranny, rear, wheels, tires, roll bar, everything!)
    Damned simple, inexpensive, low rpm, low maintenance. Now, would I put one in a Maverick? No. It's not a "bolt-in" deal with the Maverick. The Fox chassis T-Bird was easy. Maverick will take a whole new front end. I'd go with a 408 or 412 inch Windsor instead.
  4. scooper77515
    Shadow...that sounds like fun :D
    I agree with the fit part with the maverick. That is why I will likely do the 393 bore/stroke so it will all just bolt on. But I still want an MII-type suspension. I cannot stand working around those shock towers, even with my "healthy" shock tower cuts. Just too crowded under there.
