5.0 ho swap wiring recommendations or tips
Discussion in 'Technical' started by Mustangnut, Oct 26, 2014.
  1. Krazy Comet
    On the 5.0 with exhaust manifolds are mounted near the outlet, on HO with headers will be in upper area of inlet to H-pipe... You'd be smart to weld the bungs after test fitting pipe with engine installed...
    As far as rough idle cold I call BS, when the engine is first started they aren't operating anyway...
  2. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    I was hoping someone had already done this and had a picture of theirs installed or where theirs was welded. Putting motor / trans and exhast in for a bung location is a huge PITA. Was just trying to avoid that if possible.
  3. injectedmav
    injectedmav Member
    Georgia
    I used the bulk of the Mark 7 harness in mine and several other pieces of salvage harnesses. Just added the MAF circuits later when I changed to an A9L Mustang PCM.
