5.47 at 125 mph
Discussion in 'Drag Racing' started by riporter, Oct 1, 2006.
  1. riporter
    riporter Member
    Charleston S.C.
    Okay...I'm sandbaggin...that 5.69 pass was an all motor pass and will stay up unless someone posts a faster time....I'm not going to get into the opinions and politics of all motor vs. nitrous vs. alky etc. etc.
    I put a little nitrous (100 hp) on the motor to have some fun with, having no idea it would pay such benefits in time and consistency, my motor was built to run on 116 octane racing fuel which is why I don't put any more than a 100 hp shot in it.
    That said...in the off season when we rework the heads and put a little more bump stick in it it will still be a gas motor that can handle a 300 shot:D
    One cold winter night in early 2007 I wanna make a 4.9xx pass:)
  2. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    are you still legal for et & mph?
    I have no idea what the cut-off is when you get down that low :)
  3. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    As I read the rulebook, you only need an 8-point cage to qualify down to 8.5 seconds in the 1/4. Anything faster requires a funny car type cage for the driver and Rick's car has that. Rick shouldn't have too much trouble getting certified for the 7's. He's practically got a Pro Stock car.
  4. riporter
    riporter Member
    Charleston S.C.
    er...um..No:16suspect cutoff is 8.50 or 5.49 the..the car will certify to 7.50 with a driver seat cage, a chute and few other minor things.
  5. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    I figured you was getting close.....but was not for sure.
    Like you send when you got certified for FFW.....it cost a lot of money to go fast...even more to go fast legal.
  6. maverick1970
    maverick1970 MCG State Rep
    Missouri
    That is awesome congrats Rick!
  7. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    Rick, has your butt got use to all the G's yet or do you still have a little pucker at that speed?:eek:
    SWEET numbers, you keep getting MPH higher and the ET's lower, just don't forget to lift at the other end if no ones beside you:bowdown: WTG
    Terry
  8. 1badmav
    1badmav Member
    Please list chassis combo and motor combo,That is flat getting it done..My old 347 ysi carb blow thru mustang went 5.53 @ 131 on radials and thats was flat booking...Good Job!!!!
  9. riporter
    riporter Member
    Charleston S.C.
    The faster I go the more pucker there is...I hope I never get so complacent that I lose the pucker;) It's a weird thing...the 5.47 pass I knew in the first 60 ft it was gonna be the best it's ever done even though it just ran a couple hundreths slower the previous pass...I was thinkin OMG what a holeshot and almost lifted having not ever felt it launch that way before.
    badmav here's a qwik breakdown on the motor
    Ford Racing 351W SVO R block, stroked and bored to 427, 9.5 deck height
    Eagle forged crank, ATI super dampener,Eaton billet flywheel ,all internally balanced.
    Lentz forged lightweight rods, and CP forged domed pistons.
    TFS R-series 20 degree canted heads, stage 3 CNC'ed ported, 365i/275e cfm
    Super Victor intake port matched, Holley Pro-Systems 850 cfm carb customized to flow 1000 cfm
    2" primary headers to 4" collectors
    Compression around 15 to 1 and estimated HP 800+
    Car is a 72 Comet, tube chassis, 4 link, coil overs and wildwood disc on all 4 corners, 32x15 MT et drags on the rear.
    Car weighs 2545 lbs with driver.
