5 lug bolt patterns
Discussion in 'Wheels and Tires' started by joerockne, Feb 17, 2022.
  1. joerockne
    joerockne Member
    Norman, OK
    1972 Grabber Maverick
    I talked to a guy that has a couple Mavericks he might sell. They both have 5 lug wheels. He said the 74 had a 4 1/2 bolt pattern. And he said the 72 had a smaller pattern. Did Ford really have a smaller pattern for 5 lug wheels? That surprises me. Anybody seen anything like that ?
  2. Krazy Comet
    Dismal Swamp
    Definitely not in '71/'72 or earlier, all have same spacing. Ford did some asinine things, changing wheel bolt patterns wasn't one of them.
    Not 100% sure about early Falcon V8(1963), I believe some of those had 13", five lug wheels. Time to drag out Hollanders interchange.
    Shorty and rickyracer like this.
  3. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    I think ‘74 is when the hub diameter changed. About a 1/4” larger
  4. dyent
    dyent Member
    vancouver bc
    I think you are correct, went from 2.43" to larger 2.78" hub diameters........
    David
  5. joerockne
    joerockne Member
    Norman, OK
    Ok , so are you just talking about the center hub. The lugs are both still on 4 1/2"?
  6. dyent
    dyent Member
    vancouver bc
    Yes about the center hub and as far as I know, all 5 bolt studs are on 4 1/2" circle.
    David
  7. 71gold
    I think the larger center hole was for the disc brake hub.
    I found a parts car once that someone made a small hole rim fit the larger front disc hub, we had to take a sledge hammer to remove it...:smash:
    Russell and rickyracer like this.
  8. bmcdaniel
    I got a flat tire once on my way to Roundup. Found out the hard way my spare tire wheel didn't fit over my disc brake hub. :slap:
    Russell and dyent like this.
  9. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    Here are a couple of shots from the Crager catalogue. A lot of their rims have a bore of 3.579 “Also their rims in this design have end caps so you can’t see how closely the hole size is matched up with the hub diameter.
    D316FA99-A55E-4133-A566-47B037B78AEB.png F9A2C70C-FA79-40C1-90FB-A0D07E92B0CA.png
    joerockne likes this.
