5 speed swap DONE!!
Discussion in 'Transmissions' started by mustangturbo50, Mar 25, 2008.
Thread Status:
Not open for further replies.
  1. Mavaholic
    I love tis thread since I'm putting a T5 in my GT. I have one out of a 93 Cobra so it should be plenty for the motor I plan on building. For a shifter, I bought a factory NOS 3 speed shifter from Green Sales. My GT was a factory floor shifter and I kinda like that look. I will make my own mount to attach it to the T5. This way it will look like a factory 3 speed when done. I find it interesting how some have "bolt in" experiences, where others have to modify. I had to reshape the tunnel. (http://mmb.maverick.to/showthread.php?t=36382 post #79) My stock crossmember worked but I had to extend the holes and notch it to clear the bell on the trans to slide it forward enough to bolt up. I havent decided on the clutch linkage yet. I used an adapter for the trans so I will probably stick with mechanical linkage or go hydraulic so I can use a set of the shorty headers.
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    good stuff~!
  3. 74CometGT351W
    74CometGT351W Dano
    Marion, NC
    1974 Comet Gt 351W T5 8.8 .520/.545 hydraulic cam 1 5/8 headers
    I retained my factory mechanical linkage. Used the t5 bellhousing and factory mechanical clutch fork. Just drilled a few holes to put the fork pivot on the driver side and cut off the cable notch on the outside of the bell with a sawzall.:) Works great!
  4. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Does anyone have the power brakes with the T5?
  5. mustangturbo50
    mustangturbo50 Member
    bettendorf, ia
    fluid
    back to the situation... you use type f or mercon trans fluid even in the 4 speeds back to early 80s. i looked today. check aldata or call the dealer.....
  6. mustangturbo50
    bettendorf, ia
    thanks
    you may want to come down here and tell every transmission shop and all the ford dealerships and whoever put the apparently false info on aldata and on mitchell and tell them they are all wrong ..maybe you can use 70 in a nwc but dont tell me im wrong when i know you can use atf and it is highly recommended .
  7. mustangturbo50
    bettendorf, ia
    ok...
    anyways. so today i had the header melting my cable problem. did someone way someone made one that was longer? can i buy them?
  8. Jamie Miles
    Alto, GA
    I've had a few
    I can tell you for a fact that the SROD 4 speed in my '80 Mercury Capri uses 80wt. gear oil, according to the original owners manual to the car. Lonnie knows what he is talking about.
  9. mustangturbo50
    bettendorf, ia
    srod
    yeah the single rail over drive does. but that is not a borge warner t5. i have one of those sitting on the floor in my garage and yes it is gear lube. but any t5, what was it like 84 or 85 they used them all use atf or type f automatic transmission fluid. hey wanna buy the srod. it came out of a 83 gt. i cant find a shifter for it.
  10. mustangturbo50
    bettendorf, ia
    omg . this is stupid. im lookign at it right now goes past 83. im lookign right at it. go away stop bitching about something so stupid..
  11. mustangturbo50
    bettendorf, ia
    ok anyways does anyone know anything about the longer cable?
  12. Stefan
    Montreal, QC
    Alright guys, thats enough.
Thread Status:
