5-speed swap
Discussion in 'Parts Interchange' started by redneck, Nov 11, 2006.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    What kind of vehicle did you tell them you needed a flywheel for? Just tell them you have a 1971 302 Maverick .... Apparantly your clutch mounted just fine on the flywheel. Again ... I'm not sure if that will be the case if you get the correct 28oz flywheel. Compare the size of the offset weights on all your flywheels. the 28oz will have a smaller weight ..
  2. redneck
    redneck Member
    Villa Ridge MO
    1971 Ford Maverick
    i just looked at the original 289 flywheel and the 5.0 flywheel, and i can see what you were saying to bad the new ones in the car and i trusted O'Reilly's too much to compare the two before i put it in. i guess ill have to order a different one later on. thanks again for all your help, if i hadnt talked to you i still would have been scratching my head
  3. jeremy
    jeremy I build t5's
    Corona, Ca
    to the best of my knoweledge a 28 oz 157 tooth flywheel was never made for ford that was used on the t5's, unless the early flywheels from the 70's will work.
    anyhow, they changed the balance factor in 81 to 50 oz.
    http://cgi.ebay.com/ebaymotors/302-SB-FORD-28-OZ-SFI-BILLET-RACING-FLYWHEEL-JY1_W0QQcmdZViewItemQQcategoryZ46098QQihZ004QQitemZ140042172642QQrdZ1QQsspagenameZWD1V#ebayphotohosting
    not sure if that link will work or not, but I searched 28 flywheel ford and came up with one or two that would work for you
    i'm also betting they gave you the wrong one.
  4. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
  5. redneck
    redneck Member
    Villa Ridge MO
    1971 Ford Maverick
    Thanks again for all your advice, you've all been a big help
  6. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Thank you also for doing the swap at the same time that i'm also doing this. I have not got the pedals yet but i'm working on this. I'm sure this thread is not over yet though, i'm sure there will be others that will do this swap.
  7. bmcdaniel
    Centerforce makes a diaphram clutch that that has the mounting holes in the old pattern. It's what I used on my old 302 & 347 w/T5.
