6 banger running on 5
Discussion in 'Technical' started by Dan Starnes, Dec 31, 2004.
  1. MaverickRunner
    MaverickRunner Member
    North Port Florida
    73 Maverick 302
    Hey Dan the sprint looks like it is sitting high in the front end....motor out?
  2. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Conducted a multitude of complex and difficult tests today.:bs: Determined that the #5 cylinder was in place and NOT missing,:biglaugh: though it has an exhaust valve with a problem. The car on jack stands has been determined to be a Stallion and Not a Sprint.:16suspect I also have determined that it is indeed New Years and some people might have a more than normal percentage of alcohol in their blood level, myself included.:hide: . So, for the grabber, a head rework is in order. Todd, are you the Wyoming State Rep yet??
    Dan
    ps Frank, I whacked on the valve springs and rocker arm,,, no luck:huh:
  3. MaverickRunner
    North Port Florida
    73 Maverick 302
    I am sorry Dan I know its not a sprint!!!!!
    Wyoming state rep...I talked to Craig about it and I emailed??? (cant remember names!!!) but I havent heard back from him....I will try again.
  4. Dan Starnes
    West Central IL
    Yes, Dave, , it is a 200. This pic shows my widdle finger pointing to da big bad culprit. Burnt exhaust valve. With the results of the compression check on 5 cylinders, I am confident the bottom end is in good shape. Going to redo the top side of the engine. Are the lifters a pain to get out?? Or should I use dynamite?
    Dan
  5. rayzorsharp
    :eek: Wow...looks like that thing was run quite a bit with that missing cylinder. Almost got a missing valve. Too bad you're not a little closer to me. I have an entire 200 engine from a 71 with 48k actual miles. I'd take 100 bucks for it complete. It's been in storage for a while but ran perfect when I pulled it out.
  6. Dan Starnes
    West Central IL
    Ray, that is a great deal on that motor,, distance is the evil. There was some discussion on the engine bay color when this car first hit ebay. I can tell you that the black was painted over the yellow, or whatever color it actually is. I am going to pull the remains of the engine and trans and detail everything.
    Dan
  7. CyberCoder
    CyberCoder Member
    Jackson, MS
    1976 Mav
    I may be interested in that 200, I have a 76 that needs some help and I am in Jackson.
    I wonder how different the 2 engines would be?
  8. rayzorsharp
  9. 71gold
    dennis,
    Quote:
    it too had a missing cyl.
    "Since a cylinder is just empty space, how would you know if it was missing? :hmmm:"
    it's like the..."broke brakes"... thing :biglaugh:
  10. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    No its not a Grabber. But I was checking the car out right after I got it home. And I noticed that the headlights looked real similar to those on the "Shelby Maverick" so I started checking into it. I got with Marti and he determined that it was not a Shelby, BUT, it is either a BOSS-250 Maverick or a limited edition Hi-Po 250 Maruader. I was tying to keep this ifo under my hat until I had a definite answer, but since you brought it up I figured I would let you guys in on it :D
    Dan, if my count is correct, that makes 3 Mav's. Now I know the Stallion is the "boo", but is there any chance of these others making it to the Round-up?
    **** Also, to comment on Todd........you are right.....Dan Starnes and stock, do not go together :bouncy:
  11. Dan Starnes
    West Central IL
    John, my goal is to have 2 mavs at the Roundup this year. That is the goal,
    now see if life lets me do it.
    Dan
  12. Mavaholic
    Was that life or wife????
  13. DAB
    DAB MAVERICK/COMET ENTHUSIAST
    Austin, TX
    I'd like to get a life so I can bring two cars! :D
  14. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    hmmmm.....Dennis always has words of wisdom:16suspect ...from a single guy:lolup:
    life/wife....both have about the same inpack on what happens:yup:
  15. Dan Starnes
    West Central IL
    Life presents the everyday trials and tribulations. Wife says no more cars!! I aint payin attn to either.
    Dan
