6-CYL Pipe Size
Discussion in 'Technical' started by rickm, Jul 14, 2013.
  1. rickm
    rickm Member
    Owosso Mi
    I now have a 6 into 1 header for my 200-6 and wonder what is the best size pipe to run to the back ? Keep in mind that I may install a 250 head and now have a 2 barrel on it. If I go with a 250 head and bigger valves I want to already have the right size pipe for these conditions Thanks Rick
  2. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    What other modifications have you made to your engine, if any? That would help to determine what size pipe would be best. Without knowing I would not go over 2 inch inside diameter. If you have made other internal mods like bigger camshaft and higher compression etc you could go 2 1/4. I currently have a 6 into 2 header with dual exhaust and I am running a 2 inch pipe but could probably go 2 1/4 for a bit more performance.
  3. rthomas771
    After reading everything I could find about BMW and Jaguar inline 6 exhaust I decided to go with 2-1/2" with my 6-2-1 header. After the turbo muffler it spits into two 2" pipes over the axle and exits behind each rear tire. http://1bad6t.com/Maverick/maverick_43.html
  4. jsmithink
    jsmithink Member
    Colorado Springs
    1970 Maverick, 1960 2 door Comet, 1961 4 door Comet
    Nice page rthomas!
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    4-inch with a coffee can on the end.
  6. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    Nice Sound RThomas, Not The Usual Six Odd Frequency
  7. groberts101
    groberts101 Member
    Minneapolis, MN
    2 1/4 compression bends for a milder build.. and 2 1/4 mandrel bent for higher airflow and performance.
  8. 74merc
    74merc computer nerd
    1974 Comet
    That is a sweet sounding six.
  9. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    ^^^this guy. THere's also a chart and an article talking about sizing up the pipes on a six at classic inlines
    http://classicinlines.com/proddetail.asp?prod=WAE-200-ISS
    Think you should figure out how many ponies you're making and how many you want in the future.
  10. Mhackett
    Mhackett Member
    Rochester, NY
    1969.5 Maverick
    Really nice page
  11. bmcdaniel
    bmcdaniel Senile Member
    Hmmm, I didn't think a 250 head fit on a 200.
  12. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    It fits. Highly encouraged. Flows better from what I understand. May need to mill it for desired for CR
  13. rthomas771
    200 and 250 used the same exact head. Later model head had bigger intake log and larger intake valves
