67 Shelby tail light swap?
Discussion in 'Cosmetic' started by newtoford, Dec 18, 2007.
  1. RabidCustoms
    is there approx. a 3/8 inch lip around the housing on the ouside before the raised area? (any idea what I mean?:D)
  2. newtoford
    newtoford Member
    New Castle Delaware
    you mean between the outer edge of the lens to the outer edge of the steel housing when the grills are removed from the top?
  3. newtoford
    newtoford Member
    New Castle Delaware
    from the outer edge of the lens to the outer edge of the housing is 3/4'' with a step down about 1/4 out, where the grill bexle seats
    from the bottom of the lens to the bottom of the housing is 1 1/4''
  4. RabidCustoms
    I'm talking about the housing itself. if you get a chance later post a pic of the housing looking right over the top of it.
    I'm not for sure, but I think the ones you have may work if you get creative.;)
  5. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    Tony, you need to stop! :p
    Now you got me back on seeing if charger tail lights will fit on our panels. man, I have enough going on with the 8.8 posi, and now I'm thinking lights again :D
  6. newtoford
    newtoford Member
    New Castle Delaware
    i actually know a guy locally here who has some kinda mopar lights in his mav, i think they are chargers turned upside down. they were in the last issue of shorthorns.
    you might want to email mavaholic and see if he has the pic he can post. its a dark blue car owned by Dan "iforgethislastname" here in DE
  7. rayzorsharp
    It's really not that hard to get this:
  8. newtoford
    newtoford Member
    New Castle Delaware
    I think you need to write a tech article ray
    im sure were not the only ones who like shelby lights on these cars :)
    you think the procedure for the 68 lights is much diffrent then the 69?
  9. rayzorsharp
    I'm not sure how much difference there is bewteen the 68 and 69 panel and not sure I'd wanna find out. I used the 68 panel myself.
    Okay...Here's your tech article:
    1. cut out tail light holes
    2. glue shelby panel on
    3. install tail lights
    See...as easy as 1,2,3
    Well...maybe a little tougher than that. If you haven't done so, click on my restoration pics link and you might get a little better idea of what I did.
  10. newtoford
    newtoford Member
    New Castle Delaware
    so did you replace your whole tail panel or mount the fiberglass one to what was left of the original?
    im really curious to see what the tail light mounting on either version, 67/68, looks like from inside the trunk
  11. rayzorsharp
    I cut the raised portion out. I then used about the middle 12 inches of that removed section, welded it back in for the gas cap location, trimmed the fiberglas panel to fit, bonded it with 3M panel bonding adhesive, molded in the outer edges, painted, installed the lights. Only took about 2 hours to do the whole job...unless you count the other 20 hours of trial fitting. :D
  12. newtoford
    newtoford Member
    New Castle Delaware
    durr, i didnt even notice where you flatened the tail panel
    so are the lights bolted to the steel panel and the fiberglass sits around them?
  13. rayzorsharp
    Yes, there are 4 bolt holes in the T-Bird tail lights and they go thru the metal panel. The tail lights slide in fron the outside.
    If I had it to do over again I would use one of the led kits they advertise in the Mustang magazines. It would simplify a lot of things.
    http://www.mustangproject.com/ProductDisplay.aspx?id=1fa00051-9b75-420a-99e9-1e095fe528d5
  14. newtoford
    newtoford Member
    New Castle Delaware
    they got the 67's too
    but man... $500...
  15. rayzorsharp
    Got more than that in mine :huh:
