67 Shelby tail light swap?
Discussion in 'Cosmetic' started by newtoford, Dec 18, 2007.
  1. newtoford
    newtoford Member
    New Castle Delaware
    lens, trim, housing, tail panel, gas cap. i guess it does add up pretty quick. and thats just the parts
    so if you went with the LED kit would you wouldnt have had to use the shelby tail panel right?
    then again i think using the panel like you did would make it look better then just sticking the led kit on the flat stock panel
  2. rayzorsharp
    Yes, I would definitely stay with the Shelby tail panel but that's just my preference.
  3. Jamie Miles
    I just don't like sequential LED turn signals for some reason. I guess it's because the LED's turn on and off pretty much instantly, where as bulbs sort of fade on and off. Plus I don't like being able to see each individual LED. I think regular old bulbs give a nicer effect with sequential signals.
  4. newtoford
    newtoford Member
    New Castle Delaware
    have you guys seen those 1157 replacment bulbs that are just a bunch of LED's?
  5. Jamie Miles
    Yea... you have to pay attention when buying those. If you get the cheapo ones that just have a cluster of LED's pointing straight out, you'll only have one little spot of light on your tail light lense. Something like this would be what I get, so that the entire tail light is lit up like it should be. Would probably help to paint the rear part of the tail light housing glossy white to help reflect the light.
  6. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Hey Jamie any idea of a part number for those? I usually just put 2057's in but they get pretty warm.
  7. Jamie Miles
    No, I wouldn't. I came across a real good site a while back that sold LED lights like that which were a "plug and play" retrofit in all sorts of different applications. I don't remember what I was searching for when I found it. I'll have to do a bit of digging on Google to find it again.
