'68 Shelby Hood Scoop Progress Pics
Discussion in 'Technical' started by Rick Book, Feb 20, 2006.
  1. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    That, my friend, is hawt.
  2. sierra grabber
    sierra grabber Certifiable
    northern nevada
  3. Tim Wilmoth
    Tim Wilmoth Member
    Southside Va.
    1972 Comet gt
    Looks great Rick ,Nice work
  4. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    I like it!!! (y) (y) (y) It still picks up the curve of the roof and the fenders. Nice job and good idea.(y)
  5. rayzorsharp
    I like it a lot. The only thing I think would make it look better is if the angle of the scoops were at the same angle as the front of the hood. Of course that's just "my" opinion. Hell, I'd still put it on my car in a heartbeat. (y)
  6. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    I like it,alot. I would have liked the scoops to follow the contour of the hood a little more.
  7. Mavaholic
    Can you get a 3/4 shot?
  8. Cleaver
    Cleaver Member
    MD
    Chel
    Both look great to me. I think the shelby works just fine..........aaaaa if you pick the shelby hood, what are you going to do with the cowl hood?
    Cleaver
  9. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Yea I wanna see a 3/4 picture also...Looking good!
  10. MikeG747
    MikeG747 Member
    Arkansas
    AWESOME! :thumbs2:
  11. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    now that i like
  12. Jamie Miles
    Alto, GA
    I've had a few
    I like it. I would have done it a little diffrently, but looks good!
  13. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Thanks guys. I'm glad you like it, and yes, I agree the angle of the openings would look nicer if they matched that of the hood line. I think I can probably have him do that (all it takes is $$$ ).
    Not sure what you mean by "3/4". :huh:
  14. Rick Book
    Rick Book Member
    Thailand
    I told Mike (the guy with the mad skilz who bonded the two hoods together) about this site. Here's the text of an email he sent me:
    "... seen alot of guys asking so i,ll give ya some stuff to
    post. cowl hood is fiberglass to same [fg]. panel bond by 3m,
    followed by 3 to 5 layers of f.glass for extra strength
    and to help prevent cracking, sand between 2nd and 4th
    coats and finish with a very thin coat of bondo and a metal
    glaze super thin filler 3 coats of high build ppg prime,
    block 180 and reprime, never had one crack but theres
    always a first!
    shelby hood is recessed under the hood sheetmetal, instead
    of on top for extra strength, as well as help to keep egdes
    to a minimum [no filler], to keep the line with the fender
    top [no big thick edges]3m structural adhesive was used on
    this becuase of air pressure, also 3 coats of glass
    followed by sand and 3 more coats same as above, and
    minimum filler and glaze, prime same as above.
    balsa wood was used for the workability and light weight.
    wieght is the enemy! inner structure was also cut and
    lowered to allow for inner clearance of the front scoop and
    yes it is fully fuctional metal to glass ,fiber that is!
    glad you guys like it! wait till ya see the paint!later
    mike"
  15. Mavaholic
    A 3/4 view means you get the front, side, and top in the picture.
