69 1/2 key in dash
Discussion in 'General Maverick/Comet' started by William623, Jul 4, 2016.
  1. William623
    Orlando
    1973 ford maverick grabber
  2. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    The electrical connector is different. You can make an adapter if you have the connector for the 69.5 switch and the lead coming off of the column start switch.
  3. 71gold
    there looks to be several pieces missing on the one in the link.
  4. Krazy Comet
    Your signal switch won't fit early column either...
  5. William623
    Orlando
    Hmm...good information. I might just take one of my spare columns and shave the the key off then. As for the connectors, does any one having a wiring diagram for it? I can make an adaptor no problem just need to know the wires.
  6. Fordmaster169
    Coos Bay, Oregon
    When I put the 72 A/C harness in mine I just spliced the wires and made an adapter with an old ignition switch. The wires are the same color just different plug. If I am not mistaken you can get the pigtail for the 69.5 switch from a parts store. Here is the one from AutoKrafters http://www.autokrafters.com/p-12587-ignition-switch-wiring-harness.aspx
    Do you have the switch mount?
  7. William623
    Orlando
    Yes I have the switch mount, key and starter switch.
  8. Joeycomet78
    Joeycomet78 Member
    Kentucky
    1974 mercury comet
    I just picked up a so called 69 1/2. It’s pretty rough but a complete original car. I’m not sure what to do with it, fix it or part it out. I think it would be cool to fix. It still has all of the original dog dish hub caps. I have a couple of parts cars to fix the body issues, but it would take a lot. The key in the dash is pretty cool in my book. They also have a falconish bolt in gas tank that they only used in 69 1/2 and 1970.
  9. Joeycomet78
    Joeycomet78 Member
    Kentucky
    1974 mercury comet
    I actually crafted a 1967 gas tank kit out of a mustang because it was way cheaper, but it took some work. But a welder and cutting tools comes in handy.
