69.5 vs 70 maverick
Discussion in 'General Maverick/Comet' started by modern muscle, Aug 4, 2008.
  1. 69.5mav
    69.5mav Member
    Oregon
    What about a 70 1/2 Falcon?:hmmm:
  2. Jamie Miles
    Alto, GA
    I've had a few
    Yes? :rofl2:
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    See what I mean! :dance:
  4. Acornridgeman
    Wisconsin
    This is an early lens for the 70 - Note how the reverse lamp lens is much bigger. Also note there are 6 indentations for the mounting screws instead of 8 found on the later lens.
  5. jmgford
    jmgford Member
    Iowa
    Still confused.
    I have a 6/70 car. The back-up light on mine fills the area in the aluminum bezel, which looks like any later Maverick. Are you saying that the early '70's (69 1/2's) have something visably different?
  6. Acornridgeman
    Wisconsin
    These pictures will help. You can see on the early lens the reverse lamp lens fills up the entire area and the later lens shows a lot of red on the edges of the white. The early lens used 6 screws to hold it all together and the later version used 8 screws so the later lens has 8 indentations for the screws and the early only has 6 indentations. In typical Ford fashion - both lenses carry the same part number and SAE numbers.
  7. Acornridgeman
    Wisconsin
    Here is a picture from ebay. They are not a matched pair. Lens on right has large reverse lens and 6 screw location notches. Lens on left has small reverse lens and 8 screw notches.
  8. Bum's_Steer
    Bum's_Steer Member
    Arkansas
    So, because of the different number of screw indentations, if you bust or need to replace your 69.5(& 70?) Maverick's tail light lens, you have to find one from another 69.5/70?
  9. jmgford
    jmgford Member
    Iowa
    Thanks Eric! I guess I was thinking about a more dramatic difference. That's something that you would have to be looking for, to notice.
  10. Acornridgeman
    Wisconsin
    No, because the later lenses have 2 extra notches - the original six locations plus 2 more. If you put an early 6 hole lens into a later housing with 8 screws - you may have a slight clearance issue with those 2 extra screws. May drive the extra screws into the edge of the early lens a bit, but no real problem to worry about.
  11. Acornridgeman
    Wisconsin
    Just one of the weird differences for first year production. (y)
    Now how many have seen the early taillight bezels with about 6 drain holes drilled in the base? Later replaced by a slot milled into the extrusion instead of tiny holes ......... :yup:
  12. Craig Selvey
