6al and plug gaps
Discussion in 'Technical' started by jerrybromley, Mar 31, 2012.
  1. Bizzness
    Bizzness Member
    71 grabber 351w, c6 ,9" 4.56 locker, subframe, roll cage
    I hook up a tach that didn't work with my msd. And it ran like crap. And does ur msd have that green wire loop if I remember right ur suppose to cut. Just some ideas Goodluck
  2. sdb416
    sdb416 Member
    TEXAS
    No Maverick now
    What kind of tach do you have and did you make sure the tach was set on 8 cylinders? I bought a cheap one and thought the tach was bad and then found out it was set for a 4 cylinder, switched it to 8 and it worked properly.
  3. jerrybromley
    jerrybromley Member
    Michigan
    Not a Stallion,Not a Grabber, It's a STABBER ( hence knife point hood )
    Good thought on he tach .It's a cheep Sun tach and now that I think about it MSD has a list of tachs. I'll try unplugging the tach and see if it makes any difference.
  4. Bizzness
    Bizzness Member
    It was a while ago. I don't think it had a select on it. I bought it from this guy for ten bucks. I just remember it was big. I already had the car running for a while so I could totally notice the difference after I wired it in. The dyno shop gapped my plugs at 52 and my car runs fine btw
  5. sdb416
    sdb416 Member
    TEXAS
    No Maverick now
    Great! glad you got it figured out.:thumbs2:
  6. jerrybromley
    jerrybromley Member
    Michigan
    :huh:Still looking for the Stabber's problem. I disconnected the tach and nothing changed. A friend suggested maybe a vacumm leak ( it is a fresh motor maybe 25 miles). So I sprayed starting fluid around all the likely spots. No noticable change
  7. injectedmav
    injectedmav Member
    Georgia
    You can bypass the MSD altogether to test the ignition system. The cars I installed them on have a bypass adapter that plugs in to allow the car to run without the box. Some road and endurance racers run 2 boxes that they can switch on the fly in case of a failure.
    But you may have another problem. What makes you think the MSD is at fault? What other tests have you run?
  8. jerrybromley
    jerrybromley Member
    Michigan
    Just a front shot of my car
  9. jerrybromley
    jerrybromley Member
    Michigan
    The big reason I was looking at the ignition system is that I could not get the motor to run with more that .035 gap on the plugs . MSD recomends .045 to .050 on a motor with 9.5 : 1 comp. It seemed to me it should be able to run with the recomended gap. Even @ .035 I can't get it to idle @ less than 1000 rpm and it stumbles on acceleration . I'm not 100% it's the spark ...but hey you gotta start somewhere
  10. jerrybromley
    jerrybromley Member
    Michigan
    Just another shot of the engine bay
  11. jerrybromley
    jerrybromley Member
    Michigan
    Shot of the interior ( ignore the wires hanging down not quite finished)
  12. Bizzness
    Bizzness Member
    U got a really nice lookin car. Just keep grindin u will get it figured out. I had about five things go wrong when I first got mine goin. That cost me hundreds of hours tryin to figure out. I don't think it ever ends
  13. jerrybromley
    jerrybromley Member
    Michigan
    Yea I know Devils in the details .Just need to find some new ideas .I know I'll get it sooner or later
  14. Bizzness
    Bizzness Member
    Have u looked into ur carb or timing? Does it smoke
  15. mercgt73
    mercgt73 Member
    What does your cap and rotor look like?
