'70 Mav brake hoses
Discussion in 'Technical' started by NewMaverickGuy, Apr 6, 2018.
  1. NewMaverickGuy
    NewMaverickGuy Member
    Birmingham, AL
    1970 Ford Maverick
    I need to replace my brake hoses in the front and I can't loosen the connection to the metal line. Ive soaked it in penetrating fluid but no luck. I'm trying to not screw up the metal line. Also, I cant find the proper hose anywhere. Where could i get it?
  2. dyent
    dyent Member
    vancouver bc
  3. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    I cant take off the old ones. What would help get the hoses off? The connection to the hose is a little rusty and its trying to round off when I try to turn it.
  4. 71gold
    I just took mine off, I used a large pair of clamping pliers and a wrench on the hose end. the hose end will not turn so I turned the line nut. not the best way but I knew the line wrench wouldn't do it. using the large set of pliers keeps from chewing up the nut.
    good luck
  5. dyent
    dyent Member
    vancouver bc
    Seeing how you will be getting new hoses, use vice grips on the hex fitting on the drum side, as for the other end where it connects to the hard line, how is the flare nut? Ideally, a flare nut wrench would be best, as it would grab on 6 sides, lessening the chance of rounding off the nut...........if that nut is starting to round off, you can get new section of hard line, pre-made or can fabricate your own.
    If you can post a picture, then we can see how bad the fitting is and can give you a better idea on what to do......
    David
    mojo likes this.
  6. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    Alright I'll get to it as soon as I can.
