70 Maverick Project
Discussion in 'Maverick/Comet Projects' started by abesshop09, Dec 29, 2018.
Tags:
  1. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    1970 Maverick, 1998 Explorer Sport
    Really I would think that the full console would be in more demand.... I just put a new lock on it when I replaced my trunk lock....
    I didn't see any screws on the inside when I looked, will have to look again and will have to check the outside also...
    Thanks for the info
  2. yellow75
    Tillamook Oregon
    They never made a full console for a Maverick or Comet, the consolette you have is worth a couple hundred dollars in a good market if not it is great trading stock, it would be worth more if it had a working clock
  3. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    there wasn't a clock in it that I could see, that is some interesting info thanks
  4. William623
    Orlando
    1973 ford maverick grabber
    If you look near the front of the consolette closer to under the dash portion you will notice two little tabs that stick down one on each side. Those are the screw holes, the ones inside you will just have to look for. Yeah in good condition you are looking at $250ish for it if it is the clock version. Yours is the block off plate version so it is worth less than the clock version and it is a 70 model which is specific to that year so that kinda hurts the value also but they are still pretty hard to find. .
  5. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    ok thanks
  6. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    Thanks for the help got it out yesterday morning before work
    William623 likes this.
  7. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    Ok here is an update on my project, got all the carpet and padding out removed most of the sound deadening material and took a wire wheel to the floor pan to clean up the rust (See pics) and trying to find the spot welds so I know how much of the floor pan I need to get to replace the rusted through parts...
    Drivers side:
    Front
    Rear
    Passenger side:
    Rear
    passenger rear floor pan.png Passenger's side rear.png Passenger's side rear 1.png
  8. CaptainComet
    The floor looks fairly good. Only the second picture looks truly punky where section needs replacement. Of course, you can see things there that the pics may not show. In other areas try to stab through the rust with a screwdriver etc. If it survives being poked hard without puncturing it, consider just treating it with Ospho rust converter and/or Rust Bullet.
  9. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    Yes behind the driver's seat is the worst and needs to be replaced, any ideas on where the spot weld should be so I can drill them out?
    I think I found 1 or 2 but know there are more just can't see them and it looks like the seam goes over the trans hump, will this whole section have to come out? This is the first time I have tried or done any work like this so not quite sure what or where exactly to look for
  10. CaptainComet
    I made my own patch and just replaced the rusty areas on mine. The majority of my pans were still solid. Don't worry about going all the way to the seams, just cut the pan back to solid metal. I made my own patches.
    At first, I didn't cut far enough at first and welding to pitted metal just meant it was too easy to blow through it with the welder. Getting back out to full strength metal made a big difference.
    BTW, the repairs on my car were the first welding I had ever done. A quote from Car Craft .... "if you can fog a mirror, you can MIG weld". Almost true . Study YouTube and a little coaching from experienced friends goes a long way too.
    Git 'er done .....
  11. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    yes I am definitely gonna try, I got a flux core MiG welder from harbor freight and going to get a Flanger And Hole Punch Combination Tool from Eastwood, as soon as I can get it on level ground with some cement under it instead of dirt like where I have it now I will start making panels from some extra fenders and the old hood I will be taking off....
  12. Acornridgeman
    Wisconsin
  13. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    Did you use the whole mustang floor pan or just cut sections out?
    And yes one of the members to this site makes Maverick floor pans from what I read, I joined his fb page to see just haven't sent him a message yet since I'm not quite ready to start on it
  14. Acornridgeman
    Wisconsin
    Had to trim the mustang pans to fit the section I was doing. It was a bit of work but came out nicely. If I had to do it again I would definitely invest in the Maverick pans to make it easier to fit.
  15. mojo
    If your using flux core and 30 thousand wire will more-than-likely give you a lot of burn-thru on thin sheet metal.
    I have never had any satisifactory results using flux on thin sheet metal.
