70 Maverick Project
Discussion in 'Maverick/Comet Projects' started by abesshop09, Dec 29, 2018.
Tags:
  1. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I agree, it can be done but it is a pain in the butt and involves much cussing and patience!
  2. 71gold
    I would also suggest that you find where the water came in to rust out the floor pans...cowl leak, bad windshield gasket, heater box... for a few places it may be leaking.
  3. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    1970 Maverick, 1998 Explorer Sport
    I think it was the rear side window seals, the car sat outside uncovered for 2 or 3 years
  4. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    I am going to do some practice pieces first to see what happens, I can't afford to spend $300 on a MiG welder thats why I got the Harbor Freight flux core welder.... plus all my work is going to be done outside not in a garage where I could use gas with the MiG..
  5. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    I appreciate all the input, thanks....
  6. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    No not on instagram
  7. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    First time ever painting with a spray gun usually use a spray can I know I still need some practice most definitely especially in prep work, well it is serving its purpose to keep the Hood from rusting....
    6EFB3C26-E9F8-4361-BA82-B468027A37CD.png 2C686AFD-D968-41B3-8981-967FD9423C03.png
    the other side is a little better I still have to work on my prep work and adjusting my gun it is spraying way too much paint, for both sides of the hood I went through a quart of primer and that rust encapsulator primer is expensive so I really have to get it adjusted....
    stumanchu and BBMS18 like this.
  8. stumanchu
    stumanchu Stuart
    Portland, OR
    I had rust in my trunk floor. I coated the floor with POR 15 and laid fiberglass matt in it, more POR 15 and a layer of fiberglass cloth, followed by more POR 15. I used this method under my battery tray, and to a small area on my core support. None of it has cracked or delaminated in any way. Replacing the sheet metal IS optimum, and I finally did have to bite the bullet and learn to weld anyway when it came time to build an exhaust system. Keep it up.
  9. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    Thanks for the encouragement, I will keep at it...
  10. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    Just got my Marti report on my Maverick and it is supposed to be Hulla Blue
    guess that is what this color is, so will probably re-paint it this color when it is time to paint it, maybe add a ghost blue pearl to it (who knows at this point)...
    Here is the hood I bought after I primed it, but didn't prep it good enough so will have to re-prep it
    will post the updated pics of the hood I bought after I fix (sand better) and re-prime it
