70 maverick strut conversion
Discussion in 'New Members Forum' started by HDbilly, Dec 26, 2021.
  1. HDbilly
    HDbilly Member
    70 MAVERICK
    Has anybody converted a 70 maverick over to a mustang 79-93 front struts and 94-04 spindle using the stock lower control arm simlar to the RRS setup. not sure if this is doable
  2. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    I'd say it's doable. You can probably buy a top mount or fab one. But you may have to make lower arms. Just my thoughts.
  3. HDbilly
    HDbilly Member
    70 MAVERICK
    I'm going to look into it a bit closer I've been looking at the RRS setup but it's a bit pricey
  4. Probot64
    Probot64 Big Hat Racing. Ford powered Cars
    Corona Del Mar, CA
    1971 Comet GT, 64 Fairlane Pro Street, 1963 F100 Unibody, 1964 Fairlane 2 Dr Wagon
    I used the AJE K member which uses Fox struts and brakes or many of the aftermarket parts - Much cheaper
  5. bmcdaniel
    There's a company that makes a strut conversion for our cars. NICKDOMINIC on here has one. Don't remember the name of the company or details.
  6. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    RSS makes awesome stuff but they sure are proud of it.
    A quick Google search tells me the track width of a Fox body Mustang is virtually identical to a Maverick and an SN95 is only about an inch wider, so there ought to be a way to do it. The K member setup might be less invasive than an MII as well.
    Here's a thread on the AJE strut suspension. http://mmb.maverick.to/threads/aje-suspension-installed.70799/
