'70 Reverse Light Radio Bypass
Discussion in 'Technical' started by NewMaverickGuy, Jun 10, 2018.
  1. NewMaverickGuy
    NewMaverickGuy Member
    Birmingham, AL
    1970 Ford Maverick
    Is there a way to get power to the reverse lights without the radio installed? Mine was ruined and no power was getting to them even before I took the radio out.
  2. Craig Selvey
    Radio should have nothing to do with the reverse lights.
    Krazy Comet and Ronald Hopkins like this.
  3. Krazy Comet
    Possibly fed by same fuse??
    Even if that's the case tossing radio should make no difference, all backup lights require is switched power. Well and a backup light switch.
  4. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    I was led to believe that power must pass through the radio light to get to the reverse lights, like on the diagram.
  5. Krazy Comet
    That can't be the circuit wiring diagram shows.. And don't believe everything you read, especially on the net.
    The radio lamp operates from the dash light circuit. Wire the backup lights to that and you can dim them(at least till the dimmer rheostat burns up, which would be in a minute or two). You could use the radio power to operate the lights.
    Hotrock likes this.
  6. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    Ok nevermind, I figured it out. Figures i should have just looked at the fuse box.
    Craig Selvey likes this.
  7. Tristan21
    Tristan21 Member
    Marshfield, Mo
    !975 Maverick 302 4-door
    Our reverse lights do not work as well. What was your problem? Blown fuse?
  8. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    The fuse isnt blown but the tabs for the fuse were rusted pretty bad.
  9. Krazy Comet
    Meaning the cowl is likely leaking..
  10. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    previous owner hadnt stopped the leak and it was coming straight in. I sealed it back up a while back.
