70 two door to 75 four door Front suspension swap questions.
Discussion in 'Parts Interchange' started by 70GreenMonster, Oct 19, 2015.
  1. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    Also remember that changing rear shackle length changes pinion angle......................
  2. 70GreenMonster
    70GreenMonster Member
    Space Coast, Florida
    Thanks for the tip, I will keep this in mind if the springs I have don't ride well.
  3. Krazy Comet
    They are also listed for '70-'72 Maverick 6cyl and are what I used as well...
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I know, but a stock V-8 Maverick spring should not be "already too stiff". Did you put in stiffer than stock springs?
  5. Krazy Comet
    Nope. I'm talking about removing the originals...
    After the front end rebuild and install of alu headed 5.0 it was approx 1½" higher than prior... I drove it awhile like but it never began to settle, all's good with the 8088 springs...
  6. Richard Kuss
    Richard Kuss Kusstum Fabrication
    Red Bluff Ca
    1970 Ford Maverick, 1970 Maverick parts car
    I know this is old, but what will that do? I have 5inch shackles and planning on going to stock when I bought calvert split mono leafs
  7. 71gold
    what was the reason for the "5 inch shackles"?
  8. Richard Kuss
    Red Bluff Ca
    No idea. my father did it over 10yrs ago
  9. 71gold
    some people use longer shackles to compensate for sagging leaf springs. if that is the case then no pinion angle change other than getting it back to where it should be.
