72 comet 5.0 rebuild
Discussion in 'New Members Forum' started by 4DoorMav, Apr 16, 2018.
  1. Craig Selvey
    Best thing, and cheapest thing for you to do is get a Maverick power steering set-up and install that. I have the parts. Email me DIRECTLY (see below) if I can help.
  2. stumanchu
    stumanchu Stuart
    Portland, OR
    Welcome to the forum! I have hooker long tubes.... Had to get a power steering drop bracket. The steering arm also hit a tube...so I put a dent in it as far as I dared, and live with it. I used a saginaw PS pump and had to shim the pressure relief valve to lower the pressure, and use a piece of GM PS hose with a flare fitting to get it all hooked up.....but it works nice in my opinion. I am using the stock, old leaf springs (3 springs, was a 6 cyl car), and bought the lightest 6cyl coil springs for the front (did not cut them) to replace the cut springs the car came with. I wound up with a the ride height I wanted on the first try......and I feel lucky! I replaced all the rubber in my front end and retained the skinny 5/8 sway bar. The strut rods, stock spring perches, and stock control arm bushings all work to tighten up the front end to the point that the 5/8 sway bar (with new rubber on it) seems to keep it from rolling much.
  3. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    Welcome to the forum, there are at least a couple members within a half hour of you. I'm across the river from STL in IL.
  4. 4DoorMav
    4DoorMav Member
    Hillsboro MO
    74 maverick 72 comet
    Awesome, I actually found a old power steering set up I got with my first maverick, the piston is there so I'm going to go with that for now. I plan on running hydro boost for the brakes so I'm going to need a different style power steering pump to assist. My long tubes are hedman and were used so I assume they worked in my car. Just unsure if they will work around the piston for the power steering. I guess I will have to find out. But I'm looking for the engine mounts for a 5.0, the ones I have are for a different car, where it sits on the frame mounts, the opening is about a quarter inch too big. Could I just put washers between them or buy new mounts?
