72 Comet Tail light Sockets
Discussion in 'Parts Interchange' started by jasonwthompson, Sep 14, 2015.
  1. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I am trying to find the 3-wire tail light sockets for a Comet. These are different than the Maverick, they are plastic and twist into the housing. The Maverick one is a 2-wire metallic push in. I found some at O'Rileys auto that were 3-wire labeled Ford 1974-1979. They would not fit into the housing. Are these some type of special ones Ford made for one year or just for the Comet?
  2. rthomas771
    jasonwthompson likes this.
  3. dyent
    dyent Member
    vancouver bc
    jasonwthompson and rthomas771 like this.
  4. jtown77
    jtown77 Member
    Arizona
    71 Comet
    The ones Melvin's originally had did not fit. I took a bunch of pictures for them. They were suppose to get with the vendor and fix the problem. Not sure if they did.
  5. rthomas771
    What was wrong with the fit? Too long? Too fat? Too small? Would filing or trimming the ears make it fit? Can you post us a pic?
  6. jtown77
    jtown77 Member
    Arizona
    71 Comet
    They weren't even close. I actually disassembled the new ones and used the guts out of them in my old sockets.
  7. Krazy Comet
    Dismal Swamp
    I haven't worked with the brake/tail lamp socket(luckily mine are OK), but for backup I modified the keyway on back up sockets for '88 T-Bird and use those... If I remember correctly that was just cut away one tab and it fits nicely, easy as the sockets are plastic as well... Big plus is those use the far more common 1156 bulb vs the orig odd ball 1076...
  8. jasonwthompson
    Carrollton TX
    Thanks guys. I am more accustomed to getting Mustang parts that are reproduced or still available. Trying to find some of the Maverick/Comet stuff can be frustrating at times. At least it looks as if these cars are starting to catch on as I have seen a couple of new repo things show up. Anyway, if you don't have a Maverick or Comet it is probably a good time to get one before the prices creep too high and the supply too low.
