72 Grabber Hood Stripe Advice ....
Discussion in 'Cosmetic' started by dmhines, Nov 11, 2005.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Not doing Grabber stripes down the side .... The exterior is now complete .... :)
  2. Erick-Mav
    Erick-Mav Maverick Punk
    Oceanside, CA
    71 Grabber-Factory V8 w/3spd, 72 Maverick-351 Procharged for Strip, 71 Comet GT-331/4spd
    Thanks for the suggestions. I am going to add the 72 decal to my 72 Grabber Clone. I put cheap side stripe Grabber stickers on and they had tons of bubbles. I spent hours puncturing all the bubbles and squeezing the water out. It actually turned out fine, the bubbles go away after the water dries. I will try your method on the hood sticker though, but my 72 car is a "10 footer" drag car anyways, so I don't care too much.
    My 71 will have the hood stripe painted on show quality...Dan, did you use a stencil on your 71 or did you have your painter mask it off?
  3. dmhines
    Cumming, GA
    Luckily when I put the stripes on my Grabber they laid down nice and smooth ... no bubbles there ... I used dish soap and water on them. I used Windex on the hood stripe as per the suggestion of a sign shop vinyl installer ... maybe I should have stuck with soap and water ...
    The person who painted my Grabber masked out the hood stripe by hand from pictures I took prior to it being painted ...
  4. Acornridgeman
    Wisconsin
    Hey Dan - How about an update on the hood decal application. Did the bubbles ever work themselves out?
  5. dmhines
    Cumming, GA
    Yes ... bubbles are gone .... :)
  6. gunslinger68
    gunslinger68 Member
    Jackson, WI
    1970 Maverick-347,tr3550,9in,etc.etc.
    I use baby shampoo and water as well, I've always heard never to use window cleaner, has something to do with the amonia in it. I've done quite a few decals, from a T/A hood to woodgrain, and a few ' 05 Mustang lemans type stripes, the only time I've had problems with it was if I didn't have enough shampoo in the water, but you don't want too much either. I also have used a mix of distilled water and rubbing alcohol, mainly for clear stickers like stone gaurd. No residue behind the clear sticker that way.
    Just wanted to put in my :2cents: .
