72 Grabber stripes, gloss or matte black?
Discussion in 'General Maverick/Comet' started by John Holden, Mar 16, 2015.
  1. goldnrod
    goldnrod Member
    Fredericton, NB. Canada
    72 comet gt
    This info was found on the 429 megasite and may be helpful to some.
    I build Mustangs for a living and struggled for a long time to find the best paint for hoods and engine compartments as well as the lower black out area. The biggest problem you have with semi-gloss black with new paints, not lacquer, is getting an even finish. Most of them look splotchy or too flat or too glossy. The problem with most is you add a flattener to your clear, but the results are very inconsistent. I finally found PPG's DCU 2060 it is a premixed clear that already has the perfect mix. All you add is the hardener DCX61 and reducer DT 885. The ratio is 6 parts DCU 2060, 1 part DCX61, and 1 Part DT885. You use your black paint of choice IE. Dupont, PPG, R&M, whatever you like and topcoat with the PPG DCU 2060. Apply two wet coats and when its fully dried you have the perfect finish. Not only does it look good but it also is very stain resistant, you can wax it if you like it will not make it look powdery. Its great in the engine compartment for a fantastic look and a tough durable and easy to clean surface. I better quit I'm sounding like a commercial.
    Allan
    Mustang Central
  2. 71gold
    they have a matt clear now that is as maintenance free as gloss...
  3. 71Mavrk
    71Mavrk Member
    Nevada
    Yeah, If you gloss clear the rest of the hood and then satin clear only the flat black area, how do you block and buff the glossy part and not run into the satin area?
    This was my problem and why I have a sticker on my hood.
    This was not an issue back in the days of single stage paint.
    This would be something you can do on the tail panel or the core support. I wish I had done this at the time. My painter was an idiot.
    For my flat color, I just cross referenced the original Ford flat. Ford M6519D, PPG9904.
    Micah
  4. mav man
    mav man Member
    wi
    70mav
    Yes it works good but still can't wet sand or buff it if you get a scuff mark or scratch.
  5. 71gold
    can't wet sand or buff it if you get a scuff mark or scratch on a sticker either...:huh:
  6. 71Mavrk
    71Mavrk Member
    Nevada
    True, but just junk the sticker and replace.
    Micah
  7. mav man
    mav man Member
    wi
    70mav
    Yes but like I said paint it all gloss clear then it's good and durable?
  8. 71Mavrk
    71Mavrk Member
    Nevada
    What a flat '72 sticker looks like:
    Micah
