72 high back buckets
Discussion in 'Parts Interchange' started by mav man, Aug 24, 2006.
  1. L50watts
    L50watts Member
    Winchester, Virginia
    72 Maverick Grabber
    Back seats
    Are the seat stitching and pattern exactly the same?
  2. fairlaneranch
    fairlaneranch Member
    Melfa VA
    72 Comet with 161 K original miles!
    No,but the fit is (y)
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    What is the difference between the rear seat in a 71-73 Stang hardtop and convertible? Or in your case, a Cougar hartop and convertible?
    The reason I ask is that my uncle tried to put a set of 73 rears in his car with the fronts and they did not fit properly. Yeah, they were the same width and they physically clipped/bolted into place, but the shape of the side was so different it didn't match the side panels. The seat was also shorter, so passengers would sit really low. Both these combined made for a very bad looking fit. Gaps everywhere... on the sides and between the top and bottom of the seat. The covers would not swap either.
    That said, the seats were not out of a ragtop. If the ragtop has a different shape and taller top and bottom portion, it might work.
    I would be curious to know.
    Dave
  4. GRABBER70
    GRABBER70 Member
    wisconsin
    1970 maverick grabber
    just picked up some72 maverick buckets. just to be clear can I use the 1970-1972 FOAM AND COVERS from a MUSTANG?? Id like to go with either standard or the mach 1 foam and covers but not sure if theyd work. please help
  5. mercgt73
    1971-73 Mustang high back seat foams and matching covers fit 1971-72 Maverick high back bucket seats.
  6. fairlaneranch
    Melfa VA
    ragtops back seats are narrower. Man talk about an old thread!!!
  7. GRABBER70
    GRABBER70 Member
    wisconsin
    Thanks for the Info but as I took a closer look and researched I found that they are not maverick buckets but pinto buckets. Will mustang foam and covers still work? If not where can I get pinto upholstery? Will the tracks work for a maverick?
