72 Inline 6 Rebuild?
Discussion in 'New Members Forum' started by karlp, Nov 29, 2023.
  1. karlp
    karlp New Member
    Marina CA
    1972 Mercury Comet 200 CID Inline 6
    Hey everyone, happy and proud new owner of a 72 base model Comet with recently redone interior and a 3 speed on the floor. Found the head gasket was leaking oil from the rear of the gasket, so I'll be doing a full rebuild this weekend.
    Anyone done this before? Any tips, tricks, or gotchas? I've rebuilt a modern fuel injected w3800 Series III engine, so I know what I'm getting into for at least everything in the teardown and up to the timing.
  2. TeeEl
    TeeEl Senior Member
    Colorado
    Swap a V-8 in it...
    71gold likes this.
  3. Krazy Comet
    A full rebuild in a weekend? You running on 50x speed?
  4. 71gold
    save your money and go 302/5.0.
    mojo and TeeEl like this.
  5. 71gold
    :Welcome:...:Handshake:
  6. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Welcome! You'll find it a joy to work on compared to late model cars.
  7. randymachine73
    randymachine73 Member
    Central Valley, CA
    73 Maverick
    I made some guide pins when doing my head gasket. Got 2 bolts from the hardware store, that are the same thread as the head bolts. 7/16x14. But 5 inches long. Cut the head off and sharpen the end. Put one on each end of the block. Drop the gasket on, then the head. Keeps it straight.
    Powerband likes this.
  8. Craig Selvey
    One can also cut a "slot" into the end of the bolt where you cut the head off. Use a standard flat screwdriver to be able to rotate and remove the bolt.
    mojo and 71gold like this.
