72 Manual brake - auto trans
Discussion in 'Technical' started by jasonwthompson, Jul 8, 2020.
  1. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Occasionally if you slam the drivers door the brake lights come on. The wiring and connector to the brake light switch are good, it seems that either the pedal, rod, or switch slightly binds and engages the switch. Does anyone have a picture or diagram for a manual brake, auto trans pedal assembly? I am thinking the bushings may need to be replaced, but I don't know how many there are, where they are located, and how it is disassembled.
  2. Acornridgeman
    Wisconsin
    jasonwthompson likes this.
  3. jasonwthompson
    Carrollton TX
    FYI - There are 3 bushings for the brake light switch, 2 are basically washers and 1 is a bushing. In my case there was 1 washer so the setup was missing the busing and other washer. Got them in and works great, it even took some of the play out of the brake pedal.
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    File this in the back cobwebs of the brain in case it happens to me in the future!
