'72 maverick, 62d.. BELTS!!!??
Discussion in 'Parts Interchange' started by bill hoefs, Jan 5, 2020.
  1. bill hoefs
    bill hoefs Member
    wi
    1972 grabber
    Hello Everyone.
    Question = I need a set of matching pulleys and belts.
    I have put together a '72 Maverick Grabber. I have a '70 351w, 4speed Top Loader, 1 3/4 " Long tube headers. I removed the power steering pump, I have A/C. I have an electric fan installed. I have a water pump from an 84 ?? I think.. it matches up with my pulley alignment. Right now I have to roll the water pump and crank pulley belt on because no power steering pump. I have adjustable alt and A/C belt pulley. My accessories are... crank , water pump , alternator , A/C .. I would like to convert from the old style A/C compressor to a smaller version.
    Thanks Everyone.
    This sight helped me get this far.
  2. Krazy Comet
    Ford pulleys are exasperating and that's being nice.
    I'll guess you'll need a water pump pulley for a non-P/S application, that should allow operating W/pump & alt from same crank groove.
    The '67-'69 289/302/351 engines with P/S used a double groove water pump pulley that one belt operates P/S & other alt, I dunno if that pulley will align with a '70-up crank pulley. The '69 & earlier small blocks used a three bolt crank pulley that will not bolt to '70-up dampers.
    A/C should be driven from front groove on crank pulley, no change for it's operation. I have zero experience with aftermarket A/C setups.
    Here's the '67-'69 pulley arrangement I'm referring to.
    I recently installed installed P/S, on my '69 Fairlane, needed both water pump & crank pulleys.
    EDIT I just checked Ford Master Parts and the water pump pulley for '71 & '72 Maverick 302 without P/S is ID as C9OE-E, that's a '69 pulley so my above ramblings should apply. 351 & 302 use same pulleys.
  3. stumanchu
    stumanchu Stuart
    Portland, OR
    I had a hard time getting belts for my stuff because many parts houses only go by make and model, and it was...well...cobbled. Auto Zone had a device that measured the belt and gave a part # based on size, so getting one an inch longer or shorter was no big deal. You might want to pay them a visit when you get that far.
  4. mojo
    I have converted my AC to small aftermarket setup. However, I am running PS, so can't speak to your belt issue.
    I don't know if your planning to go w/ OE Ford pump or aftermarket; I got my entire setup from Classic Auto Air. If your thinking aftermarket, might want to contact them -- they may be able to advise on the pulley/belt issue.
