'72 Maverick (I need help!!!)
Discussion in 'Technical' started by JDV1992, Jun 27, 2011.
  1. PaulS
    The later tank will work but you need the straps for the tank you install.
    There will be a bit of interference between the tank and rear splash shield.
  2. Dave B
    Not necessarily, the straps will work fine, my 73 had the 73 straps holding a 76 tank, you just need longer bolts (The straps will conform to the tanks). The tanks do not hit the rear valance, that's a common misconception. I've done it twice with no issues. :Handshake
  3. mavgrab302
    Yup 76 mav tank and longer bolts work... I put a 69 mustang tank in my 71 but you have to move the straps and make a new slot on the right side for the bolt... IM going to put the 76 mav/comet tank in my 72 comet gt, less mods needed....
  4. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    Yup. Straps work fine - just need longer bolts from a hardware store. Idk about the splash guard... still looking for mine :hmmm: lol
  5. Craig Selvey
  6. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
  7. ForrestMav
    ForrestMav Member
    Alabama
    73 maverick grabber 302
    Check out autokrafters.com.. They have one that fits but is 19 gallons, and all the straps and other parts needed to do the conversion to a larger tank. Might be a bit on the spendy route but it will be done right.
  8. Dave B
    That's the 75-76 style tank we've been talking about.
  9. MeanGreen72Mav
    MeanGreen72Mav Member
    Taylor, Mi
    Don't buy it from Autokrafters. You'll get a much better deal from rock auto.(just look up a tank for a 76 Mav.) the 76-77 tank fit my 72 just fine. Its mostly just deeper. You will either have to buy the vapor valve for the 76-77 tank or get one out of the junk yard. I bought the straps to go with the tank. You will still use your old sending unit.
  10. JDV1992
    JDV1992 Member
    Charlotte, NC
    1972 Ford Maverick
    Do you know of any place online that sells the '76 Vapor Valve?
  11. MeanGreen72Mav
    Taylor, Mi
    I've found it at AutoKrafters, CJpony parts, National Parts depot, and places like that. Its about $40 plus the grommit. I had a custom one made for my tank by a friend of mine who is a tool and die maker. You will have to look around to get the best deal.
  12. JDV1992
    JDV1992 Member
    Charlotte, NC
    1972 Ford Maverick
    Ok Thanks guys. I just ordered the tank and the vapor valve. Is there anything else that I might need?
  13. JDV1992
    JDV1992 Member
    Charlotte, NC
    1972 Ford Maverick
