  1. MrBrent
    MrBrent Member
    Washington State
    1974 Maverick 302V8 Orange 2D
    "Sie haben das Recht zu schweigen. Alles was Sie sagen, kann und wird vor Gericht gegen Sie verwendet werden..." :disagree::disagree:
    (you have the right to remain silent. . .)
  2. mav1970
    Love it :bananaman:
    Thank goodness for Bing Translator LOL!
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    He was most likely on the Autobahn.
  4. Krazy Comet
    I'd have to be on a autobong to drive that fast...
    doncomfort and Rasit like this.
  5. tody
    tody Member
    cologne, germany
    the car handles incredibly well. if you read back a few pages, you can see all the issues i had. but now? front end is totally solid and feels planted.
    all in all, i didn't do that much to the suspension. mainly improved (roller) stock parts. but the vibration issues are completely gone and i'm pretty confident about the steering. still have a little whining noise, i guess it's the differential.
    i drove on a pretty flat and straight stretch tonight which was recently rebuilt - if western PA roads are anything like the eastern roads where i drove from philly to harrisburg and to mountain top to visit bob, i wouldn't have driven that fast there, either ;)
  6. Allen Small
    Allen Small Member
    Cannonsburg, PA
    73 Grabber/V8 and 72 V/8 grabber
    The roads are about the same here as at Bobs. Maybe a little worst. A lot of dips, patched potholes, hills and curves. PA has some of the worst roads I have ever seen. The auto bond would be a dream road. Even the interstates here are bad.
    I grew up in North Carolina were there were nice interstates and back roads that you could do runs like that late at night when mist people were home and asleep.
    Roads aside that is still a very impressive speed to squeeze our of these cars. You have done a great job with your car.
  7. tody
    tody Member
    cologne, germany
    picked up a set of modified lower control arms. had the opentracker sleeves and bearings welded in.
    i'll try to put them in this weekend and have the front end aligned (once again).
  8. Bryant
    need to get your alignment tools. could have paid for them by now!
    i know changing out the stock control arms made a huge difference in the feel of the car.
  9. tody
    tody Member
    cologne, germany
    lower arms are finally in. what a difference they make! up and down movement of the front end is much easier.
    car is in need of an alignment, so i don't know what to make of the handling yet.
  10. tody
    tody Member
    cologne, germany
    ordered a t5 crossmember from frank, acquired a wc t5 transmission for the mustang, the t5z ford racing transmission from the stang will go in the comet.
    don't know whether the 2.75 gears will suit it, so i will have something new to tinker with ;)
  11. Bryant
    the 2.75 gears will put a work out on the clutch to get the car moving. i would definitely recommend a ratio change. i dont have a specific suggestion sense you deal with the autobahn and much higher speeds.
  12. tody
    tody Member
    cologne, germany
    well, the toploader has gear ratios of 2.78, 1.93, 1.36 and 1.00, whereas the t5z has 1st 2.95; 2nd 1.94; 3rd 1.34.
    so i was thinking just a slight change, as i have an unused set of 3.00 gears on my shelf.
    might be better of with something in the 3.20 area, but we'll see...
  13. injectedmav
    injectedmav Member
    Georgia
    I have 3.50 now which is nice for red light to red light and mountain driving but for the highway I miss my 3.00's. I use a 94 Cobra T5 with a short input shaft which is about the same as the T5Z
  14. Bryant
    ah, i thought you had a standard t5 not a top loader. the t5z will be a little better on the clutch than the top loader. 3.0s or 3.25s should be good for the higher speeds you get to do.
  15. tody
    tody Member
    cologne, germany
    got the crossmember from 71gold, and the adapter plate for the bellhousing. Still waiting for the transmission to arrive, so nothing to do right now. Will set up the diff with the new ring and pinion when i swap the transmission.
    signed up for drag race, a just for fun event taking place in two weeks:
    http://www.drag-day.de/teilnehmende-fahrzeuge-1-4-meile-fun-race/
